Help help help help
Old Feb 24, 2011 | 03:24 PM
zerostyle's Avatar
zerostyle
Default Help help help help
3 weeks ago...motor gave out...got a new one (used) i just got it back today....and my car is making a grinding noise when upshifting only. i can hear the noise grinding and feel it in the ****...to make things even weirder i was messing around and if i push the clutch in and wait till the rpms start dropping then shift i get no grinding or noise...its not hard to get into gear....it doesnt do it while im still... anyone?
Old Feb 24, 2011 | 03:41 PM
350zbehold's Avatar
350zbehold
clutch adjustment ?
Old Feb 24, 2011 | 03:45 PM
TheFarmer's Avatar
TheFarmer
An appropriate title will yield you better results. What year is your car? I would check your clutch system (slave cylinder, adjustment, fluid, etc).
Old Feb 24, 2011 | 04:19 PM
zerostyle's Avatar
zerostyle
year is 2005...non rev up motor...?
Old Feb 24, 2011 | 05:34 PM
AJCaron12's Avatar
AJCaron12
Why are you on here posting about this when you should be bringing it back to the shop that did the work?
Old Feb 24, 2011 | 05:48 PM
zerostyle's Avatar
zerostyle
cuz i obviously dont wana drive the freaking car if its doing that and worsen the issue...so im tryna figure something out to see if i can fix it here at home. so if you dont have suggestions gtfo
Old Feb 24, 2011 | 06:17 PM
AJCaron12's Avatar
AJCaron12
I do have a suggestion. Have the shop pay for the tow truck costs.
Old Feb 24, 2011 | 06:20 PM
erichsherrill's Avatar
erichsherrill
would u also call this grinding noise a chatter maybe.. was the clutch upgraded
zerostyle's Avatar
zerostyle
Yeah lets see what excuse stealership nissan uses to not pay for that.
Old Feb 24, 2011 | 06:22 PM
zerostyle's Avatar
zerostyle
No upgraded clutch whatsoever. Look at the most recent threads in this section and see 'transmission grinding". His symptoms are EXACT to mine
Old Feb 24, 2011 | 06:25 PM
zerostyle's Avatar
zerostyle
Grinding noise when upshifting... not when downshifting...
Not the noise you get wheb clutch isnt fully engaged and try to shift....no problem getting in gears...vibes can be felt in ****...noise doesnt occur when shifting slowly. Noise doesnt occur when keeping rpms under 3k....
Ive yet to see how much fluid is in tranny. Gona replace tomorrow. I think nissan drained tranny or somewhat drained and failed to even let me know when replacing motor.
Old Feb 25, 2011 | 03:47 PM
eztax's Avatar
eztax
I replaced my tranny fluid with a different type, i forgot exactly the weight but according to the mechanic, he said it would be fine. I replaced the tranny fluid when i changed the engine and clutch....
My concerns could be wrong tranny fluid, wrong brake fluid, or the clutch went bad.... Each one seems like a far stretch but they could be a possibility...
Did you change any of those when the engione was being fixed? Maybe we can narrow down the problem together...
Old Feb 28, 2011 | 11:48 AM
VO...'s Avatar
VO...
Administrator
Good afternoon sir. Please start a new thread with a title that pertains to thread content. Thank you for your cooperation...
VO
