Modified aluminium valve covers. Part 3
Old Mar 23, 2011 | 12:13 PM
Andrei's Avatar
Andrei
Default Modified aluminium valve covers. Part 3
Someone took the Pathfinder/QX4 valve covers I tried before and modified them to fit. They want $900 which is absurd considering junk yard pieces are $50-$70.
Don't know how they modified the coil packs to seal on the surface because they did not seal when I tried it and 1 coil pack was different with an elevated mounting surface.
Their description and pics.
The 350Z never came with anything but black plastic valve covers. The stock valve covers have non-replaceable spark plug seals but ours have replaceable valve cover gaskets and spark plug seals so they will never have to be thrown away due to leaks. The stock OEM valve covers are $265 each. But we charge $450 each or $900 a pair for these. They come fully polished with new seals and gaskets installed.
Take a close look at the oil filler cap. The valve covers are designed to be seen so the stock front engine cover is no longer used. We machined a new filler housing for the oil cap to go onto. These are made from 6061 billet aluminum.
So who here had those installed since it was on a twin turbo 350z? Were the coil pack mounting surfaces modified?
Old Mar 23, 2011 | 04:36 PM
BrazenZ's Avatar
BrazenZ
Andre, I followed your thread about aftermarket valve covers, I don't know how they modified the coil packs. As for their cost, they probably went to Nissan and ordered the aluminum valve covers for >$265, machined and tapped the oil filler neck and coil packs then had the whole thing polished, $900 for locating and all of the machining and polishing they did to sell to someone else is reasonable IMO. BTW I don't own a set of these covers.
Old Mar 23, 2011 | 04:46 PM
Kwame's Avatar
Kwame
Link to the shop offering them?
Old Mar 23, 2011 | 04:50 PM
SuperBlack350z's Avatar
SuperBlack350z
http://cgi.ebay.com/ebaymotors/350Z-...Q5fAccessories
Old Mar 23, 2011 | 04:53 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
looks like the VC vent on the drivers side is missing.
would like to have a set so I could powder coat them.
Old Mar 23, 2011 | 05:03 PM
bbs350z's Avatar
bbs350z
^pretty nifty if you ask me.
Old Mar 23, 2011 | 08:52 PM
Andrei's Avatar
Andrei
The thing about the Pathfinder and QX4 valve covers is that the spark plug tube seals NEVER leak once installed, no matter the age. So it's really good for turbocharged/supercharged VQs since there wont be any surprise vacuum leaks to destroy the motor.
I guess if someone plans on staying with the VQ35DE for a lifetime, it is a good deal.
Old Dec 29, 2011 | 09:05 PM
blAk mAx's Avatar
blAk mAx
nice
Old Dec 30, 2011 | 06:11 AM
str8dum1's Avatar
str8dum1
you vent your valve covers to begin with (catch can , filters, etc) , so you never have to worry about surprise vacuum leaks from any valve cover.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
_bit
Oct 2, 2015 07:49 AM
Tochigi_236
Sep 27, 2015 03:40 PM
