03 6mt: grinding sound after cold start
Old Apr 13, 2011 | 02:30 PM
ou8thisSN's Avatar
ou8thisSN
Default 03 6mt: grinding sound after cold start
I have an '03. Sometimes when the I cold start the car, i hear a grinding sound coming. It sounds a lot like if you're trying to change gears without first pushing the clutch. The car is otherwise fine, and the check engine light isn't on or anything.
I had the exact same issue with a 1995 nissan maxima that was also a stick shift. I know that problem just went away after a while, but I cant remember how. Anyway, anyone know what im talking about? I'm sorry I cant be more specific, as I'm not very technical.
Old Apr 13, 2011 | 03:04 PM
Ak48z's Avatar
Ak48z
If it is only for a second or less when cold starting I think it is normal... or I hope so because mine does it as well I think I've read a few other people saying the same also.
Old Apr 13, 2011 | 04:37 PM
ou8thisSN's Avatar
ou8thisSN
yeah, i've noticed it only on cold start, and it only lasts a second or so. i think (or hope) we're describing the same thing. glad to know im not alone. wish I knew what was going on specifically though.
Old Apr 13, 2011 | 04:51 PM
ZS14RR's Avatar
ZS14RR
yea happened twice to me i think its something with the flywheel
Old Apr 13, 2011 | 05:25 PM
ou8thisSN's Avatar
ou8thisSN
did you do anything about it, or did it just go away?
Old Apr 13, 2011 | 05:31 PM
kacz07's Avatar
kacz07
It's this right?
Some say it's timing chain, some say it's something else. A lot of people report it and it seems like it's nothing to worry about. My built engine does the same thing and I can't remember if my first one did.
Read here, too:
http://g35driver.com/forums/130755-post14.html
http://www.youtube.com/watch?v=A2kGC...eature=related
Old Apr 14, 2011 | 12:48 PM
shiftdrift06's Avatar
shiftdrift06
Its the throwout bearing. usually when you push clutch it goes away?
Old Apr 14, 2011 | 12:53 PM
kacz07's Avatar
kacz07
Throw out bearing would rattle all the time with the clutch out, no?
Old Apr 14, 2011 | 01:04 PM
shiftdrift06
Not all the time. Mines did on my old transmission when I first start it in the cold. The grease on the shaft at first when cold would cause the throw-out bearing to stick a little when first started. I usually pump the clutch 1-2 times and the noise went away..
Old Apr 14, 2011 | 01:51 PM
Ak48z's Avatar
Ak48z
Lol my TOB rattles ALL the time the clutch is not engaged. #1 Thing I hate about my Z.
That video is the same as mine.
Old Apr 14, 2011 | 02:01 PM
Patrick250's Avatar
Patrick250
My Z would do something like that when I was using Mobil 1 oil filters. I don't think the check valve is up to par on those filters allowing the oil galleries to drain back into the pan. I switched back to Nissan filters and the noise went away. What kind of filters are you all using?
Old Apr 14, 2011 | 05:47 PM
ou8thisSN's Avatar
ou8thisSN
valvoline, as thats the last filter they put in after my oil change a week ago. the oil change before that was mobil 1. it only happens sometimes, not every cold start. but like i said, I had the exact same sound on my nissan maxima, so its not like i havent experienced it before. That had a manual tranny too.
where do you get 'nissan oil filters' anyway?
Old Apr 15, 2011 | 08:42 AM
Patrick250's Avatar
Patrick250
At the dealer. $9 each.
Obadabot
Jun 18, 2023 11:31 PM
lapham3
Oct 7, 2022 03:15 PM
