Master Cylinder
Old May 25, 2011 | 04:48 PM
onesexyz's Avatar
onesexyz
Default Master Cylinder
How do you get the d**n thing off?! I'm not new to cars by any means but I'm stuck on this one, I need to get it off, disassembled, reassembled and installe tonight. I replaced the clutch line with a SS braided one but my pedal is still losing pressure half way up. Any help would be greatly appreciated.
Old May 25, 2011 | 06:13 PM
sanford's Avatar
sanford
I got this info out of my Haynes Manual.
My scanner is not working correctly at the moment so I had to take pictures.
Hope it helps you.
Old May 25, 2011 | 06:15 PM
sanford's Avatar
sanford
double post
Old May 25, 2011 | 08:07 PM
onesexyz's Avatar
onesexyz
Hope it helps you.
Thanks man, I should've been more specific I guess lol. I meant the CLUTCH master cylinder Thanks again though for your time.
Old May 25, 2011 | 11:42 PM
MR RIZK's Avatar
MR RIZK
if you have alot of free play at the top of the pedal then remove the slave underneath the car and point the bleed nipple to the top so that the air can escape. make sure you clamp the salve piston though as when you pump the peddle the piston will shoot out.
Then bleed normally and then re-attach slave back to gearbox
Old May 26, 2011 | 07:07 AM
onesexyz's Avatar
onesexyz
I know it's bled properly, I've bled it twice since I put the SS clutch line on it. Will flipping the slave cylinder make that much of a difference?
Old May 26, 2011 | 07:14 AM
MR RIZK's Avatar
MR RIZK
I recently removed the clutch line off mine during my engine swap. When the engine went back in with a new nismo twin plate no matter how much we bled the system I had heaps of free play. No air was coming out of the system. Did some research on google and came across this issue for other cars so gave it a go. As soon as I did the peddle firmed up.
Well that was my experience
Old May 26, 2011 | 12:44 PM
sanford's Avatar
sanford
You did say that I just have selective reading. Let me know if you still need it.
07ZEKE
Aug 23, 2021 09:15 PM
sherm
Apr 11, 2020 05:21 PM
SpartanZ32
Oct 22, 2015 09:36 AM
hardkicks
Sep 20, 2015 12:28 PM
ddegrande21
Sep 6, 2015 11:15 AM
