350z FI table..(draft)
Old Dec 8, 2003 | 02:07 PM
VR3's Avatar
VR3
Post 350z FI table..(draft)
I've been developing a table to summarize all the available turbo and supercharger systems that are out so when I'm ready to go FI, if I do decide to, I have a quick reference table to look at for comparison purposes. As I'm putting this together, it hit that I'm sure others are probable interested in something like this too.
I have this table in Excel format with some hyperlinks to reference to the manufacturers' website, if available. What I linked in this post was a image of that file since I can't upload the excel file to give you glimpse of what I put together.
I still need additional information and can add and correct information that I already have per you request.
Let me what you guys think and hopefully this can be a useful tool going forward for those that may want to go FI in the future.
Old Dec 8, 2003 | 05:54 PM
VR3's Avatar
VR3
maybe this will work..
Old Dec 8, 2003 | 06:03 PM
toykilla's Avatar
toykilla
nice .. little blurry tho
Old Dec 8, 2003 | 06:10 PM
acmw's Avatar
acmw
Nice
Old Dec 9, 2003 | 05:07 AM
Juztin's Avatar
Juztin
Great research bro, can you post it's actual size though? It's kinda disfigured cause of the resizing.
Just some notes I can recommend:
--PE KIT--
The 396whp for the PE kit is only attainable if you run the 7.35 psi level which requires -
*PE's Boost Control ($495 i think)
*Technosquare ECU Reflash ($695ish)
*Otherwise it's 4 psi stock
*Fuel management = 380cc PE injectors & PE fuel pump
So it's going to be more dinero for that level of performance.
--DREAMWORKES KIT-- (Plagerized)
* Eaton 90 Roots type Supercharger
* Power output of approximately 400 hp at the crank shaft
* Dual water to air intercoolers
* Dual Auxiliary injectors
* Stainless steel braded fuel hoses
* High volume fuel rails
* Full length intake runners
* Off throttle bypass
* ECU Upgrade
* No hood or body modifications
* Construction is of lightweight cast aluminum
* Dream Works SST systems have a 3 year / 36,000 mile limited power-train warranty (warranty serviced by authorized Dream Works / Nissan / Infiniti Dealers.
* 50 State emissions legal with standard Boost
* Boost capabilities up to 12 PSI with internal engine modifications.
*5.5 psi stock
Old Dec 9, 2003 | 05:56 AM
VR3's Avatar
VR3
--PE KIT--
* ECU Upgrade
*5.5 psi stock
Thanks, I'll add it to the table. I'll try to link the original size but it's 1180x580 which is to big to upload here and I can't get it to link properly with Imagestation, Yahoo, and Fokti..I'll try again though.
Glad to see that people may find to useful in some way. It's a good reference table to compile basic info.
Old Dec 9, 2003 | 07:29 AM
Chebosto's Avatar
Chebosto
PE Info:
~8-10 hours for install.. NO cutting required. relocation of 1 resivour is needed.
ECU flash for turbo program is $595 option.
custom tuning for specific needs is additional.
fuel management is done by Fuel pressure riser, 380cc injectors. fuel pump. and ecu.
i believe there is a warranty on the turbos themselves, not on anything else. duration period i need to find out. but looks like a year.
Old Dec 9, 2003 | 09:04 AM
fluidz's Avatar
fluidz
Default ITS.....DREAMWORKES
DREAMWORKES is spelled like this!!!!!!!!....and the Stillen Intercooled system is water to air and the Stillen non intercooled system produces 292RWHP and the WATER TO AIR intercooled system produces roughly 320RWHP...last but not least, I was quoted $4,400.00 for a polished system from SUPERCHARGERSONLINE.COM for the Vortech Kit...........I was also quoted $5,250.00 for the Dreamworkes kit by Nick at Dreamworkes.
Nice chart man, thanks for the in put.
Old Dec 9, 2003 | 10:17 PM
Street Visionz, Inc.'s Avatar
With the vortech kit, would one have to sacrifice the strut bar? Maybe you could include that as one of your columns in the chart.
Old Dec 10, 2003 | 06:20 AM
VR3's Avatar
VR3
You can keep your strut bar with Vortech.
Vortech Press Release
Thanks for the suggestion and I'll add a column for that sine the Stillen kit does require a hood modification and the removal of the strut bar.
Thanks
Old Dec 10, 2003 | 11:56 PM
zland's Avatar
zland
Sport Z Magazine
I am happy to see you doing the homework and putting it in a format that is useful.
Jeff
liqalu04
Jan 2, 2022 12:58 PM
Dsowe
Feb 17, 2021 10:38 AM
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
samansharif
Sep 25, 2015 12:31 PM
