My SIKKY LS2 install thread
Old Aug 21, 2011 | 05:04 AM
  #181
Cass007's Avatar
Cass007
Filled the trans with fluid. It takes ~4 quarts of Dextron III, but you can use the Dex VI too - I used this from Castrol. I had to fab my own filler system since the filler I bought at Harbor freight didn't have a long enough hose to make it useful at all. I just butchered a small diameter garden hose I had lying around and a small funnel. Just make sure the hose is ~4' long and it will be solid.
I read up on fill procedure on LS1tech and everyone says fill till you spill. This is what you get when you ask your wife to keep an eye on the bucket
Old Aug 21, 2011 | 05:11 AM
  #182
Cass007's Avatar
Cass007
After speaking with Franz last week he informed me that the fuel system needs to be set up differently. The main supply line needs to go in to one side of the regulator, the supply to the stock LS rail fitting out the opposite side and the return down the bottom. Most of us have this Aeromotive unit and it uses -6AN fittings, but the also make a -8AN version.
Old Aug 21, 2011 | 05:39 AM
  #183
Cass007's Avatar
Cass007
The big step was setting up the main vacuum line. The LS2 port is at the rear of the plenum and orients straight towards the drivers side of the car. The stock VQ fitting is the nipple on the pass side near the battery compartment. The LS fitting is 1/2" and the VQ is 3/8", so I used two barbed fittings that threaded together to make the conversion.
My SIKKY LS2 install thread-p8191999.jpg My SIKKY LS2 install thread-p8191997.jpg My SIKKY LS2 install thread-p8192000.jpg
After much time thinking and a few calls for parts and fittings to see what my options were I just bit the bullet and drilled a hole in the firewall into the brake compartment. You can see the awesome scratch I put in the paint when the button on the drill reversed and the bit took a walk
Anyway, ran the 1/2" line into the brake compartment and then joined to the reducer fitting. Then took the stock Nissan hose that has the check valve built into it and attached the end that goes to the nipple straight to the brake booster fitting. I trimmed one bend off this side of the hose to get the proper orientation and bend inside of the compartment. Hook up the other side of the Nissan hose to the reducer fitting and its all done with the proper check valve in place
Old Aug 21, 2011 | 06:03 AM
  #184
Classy's Avatar
Classy
Attachment 320473
I laughed pretty hard
Old Aug 21, 2011 | 06:56 AM
  #185
binder's Avatar
binder
she was probably checking out the sweat beading off of your bulging muscles.
"bucket, what bucket?"
Old Aug 21, 2011 | 10:39 AM
  #186
Quamen's Avatar
Quamen
Cass,
I've been running my brake booster with the exact same Nissan hose as you did.
Old Aug 21, 2011 | 07:15 PM
  #187
Cass007's Avatar
Cass007
Originally Posted by Quamen
Cass,
Great minds thinking alike
Old Aug 23, 2011 | 03:20 PM
  #188
Cass007's Avatar
Cass007
Mega Fail today... I was bleeding the clutch and the fluid began pouring out of the bottom of the trans. I either put something together incorrectly or the slave took a crap. Either way, the car is getting shipped out for service on this issue... I JUST WANT THIS BISH ON THE ROAD NOW!!!
Thanks to JE Imports for making room for me on the schedule on a moments notice
Old Aug 23, 2011 | 03:43 PM
  #189
superchargedg's Avatar
superchargedg
Damn Noobs
James is a hella good guy.
Old Aug 23, 2011 | 04:12 PM
  #190
Cass007's Avatar
Cass007
Never met him, but I called SIKKy and they share a building, plus they have two shop cars with the swap and time is is major factor now. I've saved plenty on the install, its time to spend a few bucks and let the pros do what they do.
It took over an hour to get the car off the jack stands... its so low in the front that the race jack gets caught and won't pull out when I use the front cross member as the jack point. Thanks to my brother-in-law for his race ramps. Even putting the rear down had to be done in two stages.
Just for fun, we had a 5.9 earthquake today and I was under the car when it happened. My kid came out to the garage and said the house was shaking and I told him to knock it off... classic. Glad the jack stands held!!!
Old Aug 23, 2011 | 07:50 PM
  #191
Quamen's Avatar
Quamen
Are you near DC? I was just in DC all weekend. My brother-in-law got married in Chanilly Virginia and lives in DC.
Old Aug 23, 2011 | 08:36 PM
  #192
bigcloud's Avatar
bigcloud
Quamen I live in the DC Metro area!! I work close to Chantilly!! We could have met up! I would have bought you a beer or something!!
Old Aug 24, 2011 | 03:53 AM
  #193
Quamen's Avatar
Quamen
Sucks we missed the opportunity.
Old Aug 24, 2011 | 05:14 AM
  #194
bigcloud's Avatar
bigcloud
It's all good. Maybe if I come up there and do some snowboarding we could meet. haha.
Old Aug 24, 2011 | 05:56 PM
  #195
Cass007's Avatar
Cass007
I am ~2 hours north of DC. Wish we could have met up.
Old Aug 24, 2011 | 06:06 PM
  #196
Cass007's Avatar
Cass007
So here is the last of the mods before the car leaves to have the slave cylinder replaced.
I got the fittings in and finish plumed the fuel line.
Before:
After:
My SIKKY LS2 install thread-p8232003.jpg My SIKKY LS2 install thread-p8232002.jpg
Bought a recirculating overflow can from Jegs for $39 and a piece of aluminum flat stock from Lowes to fab a mounting bracket. Used a rubber clamp to attach the overflow line to the radiator. I believe this is the 1 quart can and it just barely fits with the fitting on the bottom. I just hope it clears the hood when shut.
My SIKKY LS2 install thread-p8232004.jpg My SIKKY LS2 install thread-p8232005.jpg
Old Aug 24, 2011 | 06:17 PM
  #197
Cass007's Avatar
Cass007
Last thing I can do here is extend the positive side of the LS sub-harness that goes to the starter and alternator. I cut off the battery terminal head first. I had ordered a one gauge connector from NAPA to make the join since the LS side has two fairly thick wires coming into it.
Trim the insulation down, then use a dremmel cutting blade to make a T cut in one side of the connector. I did this to make sure I could get both wires in securely and then wrap the connector around it tightly.
My SIKKY LS2 install thread-p8242014.jpg My SIKKY LS2 install thread-p8242013.jpg
Then get some nice thick insulated wire to make the extension to the battery and diesel the connector onto that wire. I used some 4 gauge amp wire I had lying around.
My SIKKY LS2 install thread-p8242015.jpg My SIKKY LS2 install thread-p8242016.jpg
Here is how it finished up.
Old Aug 24, 2011 | 06:24 PM
  #198
Cass007's Avatar
Cass007
I secured the LS sub-harness to the heater hoses using an old piece of coupler.
Then I put the passenger side and rear hatch plastics back together so it looks more like a car again.
Just a couple of random shots of the car on the ground. Now all I need to do is put the strut brace and hood back on.
My SIKKY LS2 install thread-p8232010.jpg My SIKKY LS2 install thread-p8232007.jpg My SIKKY LS2 install thread-p8232009.jpg
Old Aug 25, 2011 | 04:07 AM
  #199
bigcloud's Avatar
bigcloud
How far are you from starting it! I can't wait! I know youre extremely anxious!
Old Aug 25, 2011 | 05:06 AM
  #200
Cass007's Avatar
Cass007
It will be getting the slave done next week on Tuesday, then off to Diebold Autosport in VA to have the wiring and tach done. Hopefully it gets running in a week or two depending on Franz's schedule and if we hit any gremlins along the way. I already have a base map provided by Ray Hall of ViPEC that should start the car
