My SIKKY LS2 install thread
Old Sep 6, 2011 | 03:48 PM
  #241
bigcloud's Avatar
bigcloud
Almost there!!!!!!!!
Old Sep 8, 2011 | 12:18 PM
  #242
Cass007's Avatar
Cass007
Got a message from the tuner today. He said that we need to make a solid decision on the AC right now because I either need to get a different belt and exclude the AC compressor or hook up the hoses. He said the compressor will burn up if not. I opted to have the AC hooked up, the tuner will try and fab up the needed parts.
Old Sep 8, 2011 | 12:44 PM
  #243
binder's Avatar
binder
if he's at the point of tuning it why not just take the belt off to tune it then when you get it home work on getting the a/c working later? it's fall so you won't need it much and can spend your time on it over the winter.
Old Sep 8, 2011 | 04:24 PM
  #244
djamps's Avatar
djamps
Get a different belt and take time to do the A/C right later.
Old Sep 8, 2011 | 06:50 PM
  #245
bbs350z's Avatar
bbs350z
i say get it done meow so when winter is over you can enjoy your car headache free
Old Sep 10, 2011 | 09:05 AM
  #246
Cass007's Avatar
Cass007
Going this route meow. I don't want to have to drive all the way back to VA in the spring to get the AC done and I don't know anyone local that can fab an AC system from scratch. This way I can have Franz make a nice trick switch to turn it on/off, he may be able to put it in like the stock setup. Franz may also take a shot at deciphering the CANBUS once the car is running. IF he can do that he said I can ditch the Nissan ECU all together since ViPEC can control it all.
The harness is coming together and looks incredible. He put all the trans sensors on a separate sub-harness with a single master plug so if I ever need to drop the trans for a clutch upgrade or something it is a quick single disconnect.
Also, he had me send him the stock VQ oil pressure sensor that he will mount in the stock LS pressure location. This will allow him to have the oil pressure idiot light functional like the stock system. It will also allow the ViPEC to put the car in a restricted RPM mode if this light triggers. The Defi pressure gauge will move to the remote filter head with a 1/8 NPT extension.
Old Sep 10, 2011 | 09:57 AM
  #247
binder's Avatar
binder
That pressure light is bunk. I took the sensor out of my g35. If the sensor wire is unplugged the light stays off so basically that means if the sensor fails it won't alert you of low pressure. This is the reason when i lost that oil back in january why my light never came on. One would think the smart thing would be if that sensor tripped the light if unplugged but it doesnt. crap on nissans part.
Old Sep 10, 2011 | 11:02 AM
  #248
10-E-C-350Z's Avatar
10-E-C-350Z
Wow Cass, this is an awesome thread! Thanks for the good read.
Old Sep 10, 2011 | 11:48 AM
  #249
lgear080's Avatar
lgear080
I'm keeping my fingers crossed for ya.
I agree w the ac...
Old Sep 10, 2011 | 08:21 PM
  #250
bbs350z's Avatar
bbs350z
wow awesome dude. keep me updated on that ac situation, this guy might have a future customer. nothing like ahving a bad *** car with tons of power, and ac lol (dimitri likes the ac)
Old Sep 11, 2011 | 08:06 AM
  #251
Royal_T's Avatar
Royal_T
^^ who needs AC!?!?!....
J/K this is really great for those that want AC
Old Sep 11, 2011 | 01:34 PM
  #252
bbs350z's Avatar
bbs350z
<---- this guy, who does not appreciate the sweaty *****
Old Sep 11, 2011 | 03:39 PM
  #253
Cass007's Avatar
Cass007
My wife, cause she doesn't appreciate them either
Old Sep 11, 2011 | 04:06 PM
  #254
binder's Avatar
binder
no wife in car
because racecar!!!!
Old Sep 11, 2011 | 05:03 PM
  #255
0jiggy0's Avatar
0jiggy0
Nice updates. I'm confused on how an h pipe provides any benefit over and xpipe. Never heard of that.
Old Sep 12, 2011 | 05:11 AM
  #256
Cass007's Avatar
Cass007
James Evans (owner of JE) said that they had done both methods and the dyno results showed the H-pipe yeilded more TQ. Possibly because of a bit more back pressure with an NA application
Regardless, I just wanted some type of crossover to see if it could lessen the drone a bit while cruising on the highway. With 1-7/8" headers into a 3.5" collector into 3" duals its gonna flow just fine and be loud enough to make babies cry.
Old Sep 12, 2011 | 05:33 AM
  #257
Royal_T's Avatar
Royal_T
^^ very interesting.... I was planning on running QTP cutouts for the track and have them closed for driving around town with a X-pipe..
Old Sep 19, 2011 | 08:16 AM
  #258
Cass007's Avatar
Cass007
The harness is complete and has been test fit to the car. Franz is out of the country tuning for the bulk of this week, but if all goes well the car should be running shortly after he gets back. I have a few random pics of the harness on the car.
My SIKKY LS2 install thread-1316363175486.jpg My SIKKY LS2 install thread-1316363175940.jpg My SIKKY LS2 install thread-1316363176537.jpg
Old Sep 19, 2011 | 08:19 AM
  #259
Cass007's Avatar
Cass007
My SIKKY LS2 install thread-1316363176737.jpg My SIKKY LS2 install thread-1316363177582.jpg My SIKKY LS2 install thread-1316363177869.jpg
Next up is the AC lines and the switch for the compressor in the car. He also had to fix one of the coolant lines that JE did, it was pinching the hose connection shut.
Old Sep 19, 2011 | 05:10 PM
  #260
rrmedicx's Avatar
rrmedicx
Chris I am rooting for you man. You have truly been thru hell and back with this car and you deserve some serious WIN!!!
In fact that should be your text messaging ring tone...that Charlie Sheen quote: "Winning!"
LOL
Good Luck!! ---Sub'd for the results!
