Clutch still sticking after everything is replaced
Old Jul 30, 2011 | 08:07 PM
Slick 6MT's Avatar
Slick 6MT
Question Clutch still sticking after everything is replaced
Well pretty much everything. I've done extensive searching and everyone's suggestion is to put a ss clutch line on, put new fluid and bleed the hell out of it. If that doesn't cure it then replace the slave and master cylinder. None of this has worked for me.
So as of right now I've replaced the following items and it's still sticking about ~20% from the top:
-clutch
-flywheel
-ss line
-master cylinder
-slave cylinder
Any thoughts? What's left to replace?
Thanks
Old Jul 30, 2011 | 11:21 PM
kramykram's Avatar
kramykram
try this. I have suggested many times but no one has ever said if it worked or not. get a turkey injector. take the needle off and put a vacuum hose on it. make sure it will fit the bleeder valve and not come off when pressure is applied. your going to reverse feed the slave fluid. take the cap off the fluid reservoir because its going to shot fluid out the top. so fill the syringe up with fluid put the hose on your bleeder valve, open it, and then feed the fluid thru. try to have 2 people there to do this. I did it with one and a broom handle but 2 will make it easier. but after you feed fluid thru it, bleed it 2 times like normal. then feed more fluid thru the slave. wash and repeat about 3 or 4 times and see what you get. please let me know if this works for you.
Old Aug 9, 2011 | 02:16 PM
Slick 6MT's Avatar
Slick 6MT
Anyone else?
Old Aug 9, 2011 | 04:04 PM
lgear080's Avatar
lgear080
gg check it out yet?
07ZEKE
Aug 23, 2021 09:15 PM
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
