Can a Clutch be installed with out a alignment tool?
Old Aug 30, 2011 | 11:44 AM
AZHR's Avatar
AZHR
Default Can a Clutch be installed with out a alignment tool?
Hey guys,
I have a 08 z, got all my stuff in for the clutch and flywheel, and I found out that act did not send a alignment tool. No one around here sells anything for z's and no word from act. Any help?
Old Aug 30, 2011 | 12:14 PM
bmccann101's Avatar
bmccann101
Originally Posted by AZHR
Hey guys,
uh, are you in AK or AZ at the moment?
Cuz thers a million places here that sell Z parts that would lend you one.
Intense Motorsports
Concept Z performance
Vivid Racing...
and would send you one if ACT does not.
Old Aug 30, 2011 | 12:24 PM
e30cabrio's Avatar
e30cabrio
I have the one that came with my ACT HD & Streetlite. Assuming you are in AZ I'd lend it to you.
Old Aug 30, 2011 | 12:32 PM
AZHR's Avatar
AZHR
Sorry I'm in ak at the moment
Old Aug 30, 2011 | 12:44 PM
AngelsVQ's Avatar
AngelsVQ
You can it's just difficult. U have to make sure the teeth are ligned up. Go to auto zone, kragen, a tranny shop! Ask them to let u borrow it
Old Aug 30, 2011 | 02:01 PM
AZHR's Avatar
AZHR
no dice called everyone in AK, only napa has a universal one. guess ill try that
Old Aug 30, 2011 | 02:07 PM
AZHR's Avatar
AZHR
no go on the napa one, they did not have one. any other thoughts?
Old Aug 30, 2011 | 02:09 PM
e30cabrio's Avatar
e30cabrio
Maybe xoulu is still driving through and can pick one up?
Here is his thread:
https://my350z.com/forum/the-lounge-...an-marcos.html
Old Aug 30, 2011 | 02:27 PM
bmccann101's Avatar
bmccann101
true true.. OP, do you live in Anchorage?
( born n raised to 23 in FBKS btw.. aka armpit of the world)
Xoulou is the GTR /ebay auction guy.. hit him up and see. Hes on his way back to Anchorage. Not sure if hes back yet etc.
Old Aug 30, 2011 | 02:51 PM
AngelsVQ's Avatar
AngelsVQ
Sux. I've had my Clutch tool flating aound in my car for a year now -_- if only u where local.
Did u try local tranny shops? Mechanics?
Old Aug 30, 2011 | 04:45 PM
failsafe306's Avatar
failsafe306
go to an auto parts store and see if you can borrow the tool out of one of the cheapo maxima/altima clutch kits.
Old Aug 30, 2011 | 08:48 PM
Nealoc187's Avatar
Nealoc187
yes it can be installed without an alignment too. in fact i've done more clutches without an alignment tool than with one. you just have to use your brain a little bit and get a good visual angle on it to line it up. it's not very hard. you might save yourself 5 minutes with an alignment tool, but not having one certainly isn't the end of the world. heck, you can make one with a socket (or some other cylindrical implement) and some tape if you really need to.
Old Aug 30, 2011 | 10:23 PM
PDX_Racer's Avatar
PDX_Racer
Also, perhaps leaving the transmission in gear (5th? 6th?) could allow you to slightly turn the output shaft to turn the input shaft?
Old Aug 30, 2011 | 10:50 PM
Italianjoe1's Avatar
Italianjoe1
The alignment tool is for ease of centering the disc under the pressure plate in the exact middle so the input shaft can pass all the way through and still line up properly. You can center it with a deep socket that has a taper on it, usually will center up with the pilot bushing close enough, while you bolt down the PP, so that the trans goes in easy. Turning the input shaft won't address the alignment problem that would result from not lining it up somehow, either with a tool or by hand.
Old Sep 1, 2011 | 10:05 AM
Asterix's Avatar
Asterix
Old cheapo trick - start with a wood dowel smaller than needed and wrap it with duct tape until it's the right shape and diameter. That's better than nothing to me.
Old Sep 1, 2011 | 11:07 AM
str8dum1's Avatar
str8dum1
hope its not a multi-disc clutch...
good luck
Old Sep 1, 2011 | 12:13 PM
122554's Avatar
122554
I used a broom handle the last time I did a clutch, worked perfect!
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
