How does VDC/TCS cut power
Old Dec 15, 2003 | 09:44 AM
g356gear's Avatar
g356gear
Default How does VDC/TCS cut power
I am curious if the ecu pulls fuel or timing from the motor when the traction control is engaged...there is a definite power loss. I am asking because I wonder how this would affect a timing computer installed on say a Vortech kit.....for that matter even a J&S Ultrasafeguard.
Old Dec 15, 2003 | 09:55 AM
azrael's Avatar
azrael
I've heard that TCS modulates the throttle. Since we have a drive-by-wire system, the ECU is in full control of our throttle at all times.
VDC also independently modulates the four brake calipers for dynamic control of the vehicle.
I'm not 100% sure of this information, though. I'm hoping to obtain a service manual soon, and at that point I will hopefully be able to confirm this, among other things.
Old Dec 15, 2003 | 10:57 AM
SteveZzz's Avatar
SteveZzz
TCS simply cuts fuel to one or more cylinders as needed. VDC does this, plus brakes wheels if needed.
Old Dec 15, 2003 | 02:05 PM
g356gear's Avatar
g356gear
If this is the case......this would cause a severe lean condition under boost if the TCS came on.......very bad indeed.....bbooom!
Old Dec 15, 2003 | 03:10 PM
12SecZ's Avatar
12SecZ
nah it throttles down when slipping it doesn't cut fuel.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sales@czp
Sep 23, 2019 03:30 PM
codek
Sep 28, 2015 03:03 AM
Tochigi_236
Sep 27, 2015 03:40 PM
