350EVO.....Fluidyne street version radiator
Haven't installed procharger yet, not sure if and when I will.
But, looked at both manuals (04 Coupe and Z) and the Radiators seem to have the mounting tabs in the same places. The only big difference seems to be the Overflow cap. So, if the measurements were the same, you may be able to use it and just run a longer overflow line, like on the Z Hope this helps.
well i have a few questions related to the radiator. is flex-a-lite making bolt on fans for it? and which way should you blow the accesory fans? you can pull or push, but i just wanted to know the difference and if its worth it. i would be grateful for any help. thanks
