Godspeed Engine Damper Install Help
Old Oct 11, 2011 | 02:37 PM
phreaktor's Avatar
phreaktor
Design Engineer
Exclamation Godspeed Engine Damper Install Help
Does anyone have one of these? Do you have the instructions or at least some photos of how it is installed? Can't find anything online. Thanks in advance...
http://www.350zupgrades.com/20032008...-p-245678.html
Old Oct 11, 2011 | 03:46 PM
Kwame's Avatar
Kwame
Look for pictures of the Stillen damper it's the exact same thing and has been installed several times.
Old Oct 11, 2011 | 04:36 PM
headhunterx's Avatar
headhunterx
Go here : https://my350z.com/forum/engine-and-...nd-review.html
For instructions.
Old Oct 11, 2011 | 05:01 PM
ChuckW's Avatar
ChuckW
http://www.stillen.com/product_files/307360~inst.pdf
Oh, and use locktite.
Old Oct 11, 2011 | 07:04 PM
bbs350z's Avatar
bbs350z
i remember it was a pain in the *** getting those lower bolts in there circa 2007 lol
Old Oct 12, 2011 | 04:14 AM
phreaktor's Avatar
phreaktor
Design Engineer
I love you guise. Thank you! I'm installing this because I keep having exhaust cracking problems after my Berk TP install. Hopefully this fixes it for good as I have had this thing welded up about 5 times.
Old Oct 12, 2011 | 08:03 AM
killerbee's Avatar
killerbee
Yea its a pain in the *** to install.... So much that when i bought it local from a guy he never installed it because it was such a pain...but i did
Old Oct 12, 2011 | 08:06 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
go with solid motor mounts
Old Oct 12, 2011 | 08:16 AM
killerbee's Avatar
killerbee
/\ if your car is a daily i wouldn't, ever ride around in a car with solid motor mounts...very harsh and everything rattles until u step on the gas
Old Oct 12, 2011 | 08:21 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
I have SMM, its not bad at all. You wouldn't know I had them unless i told you.
Old Oct 12, 2011 | 12:56 PM
bbs350z's Avatar
bbs350z
not true, my evo had braces galore and solid mounts and was a pleasure. solid mounts are the truth phreak, cant go wrong
Old Oct 16, 2011 | 05:43 AM
phreaktor's Avatar
phreaktor
Design Engineer
Damn, how the hell do you access those lower bolts? Also, there is no mention of the bronze bracket on the left in the manual? It also seems like the bracket on min is different and there is only one threaded hole on the timing chain cover or block to bolt to. The instructions are for an 07-08 because it tells you to remove the passenger side airbox. I'm lost.
Old Oct 16, 2011 | 06:33 AM
phreaktor's Avatar
phreaktor
Design Engineer
Originally Posted by ChuckW
Those are the incorrect instructions. Here are the ones for the kit in the op:
http://www.stillen.com/product_files/307355~inst.pdf
Old Oct 16, 2011 | 07:20 AM
winchman's Avatar
winchman
Here's some pictures from another site that look like your kit.
This one shows the rerouted ground wire, so apparently you need to remove one to install the kit.
Old Oct 16, 2011 | 08:11 AM
Kwame's Avatar
Kwame
Lol, those are my pictures from when I did my install. I totally forgot that I took pictures.
Old Oct 16, 2011 | 08:53 AM
phreaktor's Avatar
phreaktor
Design Engineer
I'm in the middle of the install as we speak. Super easy so far. Three Allen wrenches, 10mm and 12mm socket, 12" extentsion, and an adjustable wrench. Thanks for the pix!
Old Oct 17, 2011 | 03:54 AM
phreaktor's Avatar
phreaktor
Design Engineer
Install was pretty easy. Not sure why people have so much trouble. the acceleration feels more "linear" than before. I havent had a chance to see if the engine is more stable yet, but hopefully my exhaust is good to go now..
Old Oct 17, 2011 | 05:19 AM
abushong504's Avatar
abushong504
Nice on the install. I would suggest solid motor mounts as well if you continue to have a problem. The harshness is not that bad at all. Also, you can install while the motor is still in the car so it's not too bad!
Old Nov 1, 2011 | 08:36 PM
killerbee's Avatar
killerbee
look here:
http://www.youtube.com/watch?v=huORpgTtwxE
the truth straight from the mouth of a vendor...and for the record they are awesome, but to daily not for most people including me, but thats just imho.
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
