I only get smooth shifts in cold weather
Old Nov 2, 2011 | 07:37 AM
TDZ10's Avatar
TDZ10
Default I only get smooth shifts in cold weather
I can't seem to figure out why my shifts feel so notchy and slow in the summer time, but for some reason they shift buttery smooth in the winter. Seems like it would be the opposite.
I'm guessing it has something to do with the transmission fluid I'm using which is half redline mt-90 and half redline mtl. Can you guys shed any light on the situation?
Old Nov 2, 2011 | 07:42 AM
MI 35th's Avatar
MI 35th
OGPremierMafia
weird, when its cold out I let my car warm up for 10 minutes otherwise it has a hard time going back into first.
Old Nov 2, 2011 | 07:43 AM
dmroberson's Avatar
dmroberson
I have been using that mixture in my Z since I bought it back in 06, and have never had any issues. I doubt it's the oil itself. I usually let my car warm up for a few mins anyway.
Old Nov 2, 2011 | 08:25 AM
TDZ10's Avatar
TDZ10
That's how I figured it was supposed to work. It makes no sense. Once the temperature dips to below 50 i get smooth shifts all of the sudden. I just want to figure out why this is so I can make it shift smooth all the time.
My 1st to 2nd shift is always clunky as hell which makes it impossible take off fast from a stoplight, but that issue disappears in cold weather.
Old Nov 2, 2011 | 09:46 AM
MI 35th's Avatar
MI 35th
OGPremierMafia
bad synchros?
Old Nov 2, 2011 | 12:20 PM
westbank23's Avatar
westbank23
I got the same problem.once my car gets warmed up 2-3rd gears are hard.
I'm running amsoil btw
Old Nov 2, 2011 | 12:22 PM
soleil's Avatar
soleil
NolaZcc
ur a ******...i live in harvey
Old Nov 2, 2011 | 12:37 PM
TDZ10's Avatar
TDZ10
Originally Posted by MI 35th
bad synchros?
could be. 5th gear will grind unless i granny shift it. But other than that all of the gears work fine. And by fine I mean notchy like every other Z. Bad syncros doesn't really explain why the shifting would all of the sudden smooth out when it's cold outside though.
Old Nov 2, 2011 | 12:51 PM
westbank23's Avatar
westbank23
Haha I live in gretna
Old Nov 2, 2011 | 11:52 PM
terrasmak's Avatar
About 50 degrees and colder and my car gets harder to shift untill its warmed up. Happened on both of my Z's.
Amsoil in 1 and OEM in the other.
Old Nov 13, 2011 | 02:14 PM
Earmuffs's Avatar
Earmuffs
no more minds interested in this?
Old Nov 13, 2011 | 05:11 PM
350Z Project X's Avatar
350Z Project X
thats really odd, cause mine is clunky when cold and smooth when hot, maybe prior owner grinding gears or not changing oil regularly. how many miles on it?
lapham3
Oct 7, 2022 03:15 PM
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
