Too good to be true clutch.
Old Nov 21, 2011 | 10:09 AM
StrangeBlubber's Avatar
StrangeBlubber
Exclamation Too good to be true clutch.
Alrighty guys. So my completely stock Nissan 350z has lost all grip with the clutch, so it is time to fork the cash for a new one.
I'm looking for a clutch to get me moving again, I don't race this car. I don't track it, or anything of that sort. I just need it to get me to work again.
So I found a clutch on the infamous Ebay. And I need to know, if this is just a complete scam.
F1 - Racing Stage 1 Clutch Kit
Who ever can help me with this, or point me in a better direction. Many thanks in advance!
Kane.
Old Nov 21, 2011 | 10:12 AM
djamps's Avatar
djamps
Consider the labor will most likely outweigh the cost of the clutch, why cheap out on the clutch itself? Last thing you want to do is crack it open again and absorb x2 labor.
Also don't forget the flywheel, because your stock one is toast and you can't resurface them. JWT clutch/flywheel combo is the best bang for the buck IMO.
Old Nov 21, 2011 | 10:23 AM
What is the price here: http://www.gripforce.com/store/ ?
Old Nov 21, 2011 | 10:31 AM
StrangeBlubber
Kits ranging from $240-290
http://gripforce.com/store/index.php...cPath=3_40_115
Thanks for all the help guys.
@djamps: I agree, the labor will be hefty. VERY HEFTY. But a flywheel is included if I am not mistaken. And If I drive impeccably. And treat the clutch with respect. It should last me.
Old Nov 21, 2011 | 10:57 AM
Cass007's Avatar
Cass007
Looking at the initial link you provided I don't see any mention of a flywheel being included. +1 on the JWT being a great stock feeling clutch.
OP, if cost is an issue, why not just search the classifieds for guys that are upgrading and selling their stock setups
Old Nov 21, 2011 | 11:06 AM
StrangeBlubber
Thanks Cass. I will go take a peek at the classifieds, I didn't see any. But maybe it just needs another once over.
Also, here are the clutch & flywheel packages.
http://gripforce.com/store/index.php...cPath=3_40_229
Old Nov 21, 2011 | 11:07 AM
bbs350z's Avatar
bbs350z
the stock flywheel is a dual mass setup and cant be resurfaced. i say jwt-tried and true easily the best clutch out there for the money
Old Nov 21, 2011 | 11:44 AM
$419 for clutch plus flywheel is a deal. Be aware that shops may add a surcharge for BYO parts. Figure 20 percent.
Old Nov 21, 2011 | 01:20 PM
StrangeBlubber
I know a guy down at believe it or not, brakes plus who was recommended by a co-worker that suggested I try and find a BYO part. Since all his dealers would give terrible rates.
He's a good guy.
Old Nov 21, 2011 | 01:56 PM
musubi's Avatar
musubi
You may want to consider a heavier aftermarket flywheel, if you're looking for driveability closer to stock. I hear JWT is good, but on the lighter side (unless that's what you're looking for) and contributes to chatter a bit more. Southbend has a heavier flywheel aiming to reduce chatter. Just my 2 cents.
Old Nov 21, 2011 | 01:57 PM
2bad240's Avatar
2bad240
i have stock flywheel and a f1 stage 3 with no issues.
Old Nov 21, 2011 | 02:08 PM
dirtbikr's Avatar
dirtbikr
Just curious why the dual mass flywheel shouldn't be resurfaced? Brought my buddy's flywheel to our "family" machinist who has been doing our work for the past 30 years. Besides saying it was difficult to set up, he said the whole process went smoothly. The clutch was replaced ~ 20k miles ago. Not an issue as of now...
EDIT: did the search thing:
https://my350z.com/forum/engine-and-...questions.html
According to that, a competent machinist can resurface a dual mass without issue. Finding that competent machinist is the problem...
Old Nov 21, 2011 | 03:18 PM
Cass007's Avatar
Cass007
I think its a cost prohibitive issue with the machining. If you know someone or can set up a grinding table yourself ( I would think the diameter is too large for a lathe) then maybe its worth it.
Old Nov 21, 2011 | 03:20 PM
Members has given technical explanations, but the OEM flywheel is not designed to be resurfaced. Machinists familiar with cutting a one-piece flywheel will say no.
May 30, 2017 03:28 PM
Dymsi
Sep 29, 2015 11:32 AM
