Gauge Routing From Engine Bay
Old Nov 23, 2011 | 09:59 AM
TurboBob's Avatar
TurboBob
Default Gauge Routing From Engine Bay
I am planning to install a boost gauge and oil temperature gauge on my 07 350Z base model. I would like to know some of the routing paths from the engine compartment to the dash area. I noted on one of the DYI posts they show a grommet located in the battery compartment area. Is this behind the battery as it is not visible with the battery in place? Also, are there other better penetration locations?
Thanks for any info.
Old Nov 23, 2011 | 10:34 AM
Ruthless18x's Avatar
Ruthless18x
There is a great spot behind the driver side front fender liner. That's where all mine are routed through.
Old Nov 23, 2011 | 12:54 PM
bmccann101's Avatar
bmccann101
Originally Posted by TurboBob
..... are there other better penetration locations?
I can think of three, but i cant post pics that will be of any help.
I know guys who have found FIVE places for penetration, but I dont believe it.
Ill chek pronhub later to see if the facts check out.
Old Nov 23, 2011 | 02:56 PM
SLIdEwAyZ25's Avatar
SLIdEwAyZ25
i can confirm their is atleast 5 penitration locaton's im looiking into the 6th as we speak.....
but if your talking about your car i routed my wideband threw a gromet hole behind the battery it's tight so you might have to notch it to fit the wires threw
Old Nov 23, 2011 | 02:58 PM
bmccann101's Avatar
bmccann101
Haha. Your looking into the 6th now? Ew.. what does it look like..and no..was not talking about a car ha.
Old Nov 23, 2011 | 06:07 PM
TurboBob's Avatar
TurboBob
Thanks, but do you mean the fender protectors in the wheel arch, or where the brake master cylinder is located?
Bob
Old Nov 23, 2011 | 07:38 PM
binder's Avatar
binder
Bob
I've routed some through a gromet that is about 1/2" in diameter. Right by the fuse box but on the firewall.
I use most of my stuff for my ecu through the oem wiring harness grommet up on the passenger side though.
Old Nov 23, 2011 | 08:01 PM
TurboBob's Avatar
TurboBob
Thanks Jeff. I found a picture of where the gourmet is on the passenger side. I will take a look tomorrow on my car but that looks like a good place to run the wires.
Bob
Old Nov 24, 2011 | 06:07 AM
Cass007's Avatar
Cass007
Bob
The main harness grommet on pass side is not really behind the battery. Remove the battery cover (4 push pins I think), then two more pins to remove the plastic piece for the cowl under the pass side wiper. Up at the top left you will see the main harness, if it is untouched from the factory you may have to remove some shrink wrap or tape to get to the rubber grommet. You can run it through there and it will drop into the passenger foot well.
There is another grommet on the pass side if you remove the rear side of the front fender liner. Another grommet on the drivers side near the steering column as well, but its difficult to get to without the engine out or the car on a lift. I hope this helps.
Old Nov 24, 2011 | 06:16 AM
Cass007's Avatar
Cass007
https://my350z.com/forum/audio-and-v...-firewall.html
https://my350z.com/forum/attachments...batterhelp.jpg
https://my350z.com/forum/attachments...y-dscn0025.jpg
Old Nov 24, 2011 | 08:23 AM
TurboBob's Avatar
TurboBob
Cass007
Thanks for the pics. I actually found the first link you listed after I posted the question here, as I mentioned above. I have already replaced my battery so I am familiar with the panels in that area. Thanks again.
Bob
Old Nov 24, 2011 | 09:28 AM
bbs350z's Avatar
bbs350z
i just drilled holes because im a lazy bastard. theres my 6th hole for penetrashunzzz
3vilbunny
Jul 18, 2017 05:10 PM
