Rev Up Complete Swap
Old Nov 23, 2011 | 07:51 PM
Z_enthusiast's Avatar
Z_enthusiast
Default Rev Up Complete Swap
I know this has been talked about a good bit and have researched a bit and got a little info from each thread and hoping to put it together and confirm a few things..
Ill be swapping a single turbo rev up (complete engine) into my 03z. The guy is going to a Ls swap so ill be getting EVERYTHING besides his wireing harness. After researching i found that theres an extra cam sensor on the heads but given that im getting the complete set up all ill need to buy would be a wire harness since he'll be getting his harness custom for the LS swap. and for ECU he is using Split Second. which ive heard/read isnt that great. So given my situation, a Engine harness and a standalone (utec/haltech) then id be Good to go correct? Thanks!
Old Nov 23, 2011 | 10:04 PM
bbs350z's Avatar
bbs350z
youd need harness, ecu, key reprogramming. with any standalone youd still need the oem ecu to operate NATS etc.
Old Nov 24, 2011 | 03:58 AM
silvertouringz's Avatar
silvertouringz
get an 06 ECU and program the key. ull be gd to go
Old Nov 24, 2011 | 05:09 AM
Z_enthusiast
Thanks! I've saw that some have trouble with used ecu's but as long as you get you register the ecu to your car/keys you'll be fine correct?
Old Nov 24, 2011 | 05:34 AM
Cass007's Avatar
Cass007
I thought you could run a rev-up like a DE and just not plug in the additional cam sensors. I believe it was Turbo Tim that told me that.
Old Nov 24, 2011 | 07:11 AM
Z_enthusiast
See, I read that somewhere also. But might as well get a rev up harness and just run it with the rev up complete engine. Not like I'm peicing this thing together.
Old Nov 24, 2011 | 07:29 AM
VQ35deMax's Avatar
VQ35deMax
These might do the trick? http://www.injectedperformance.com/i...for350zg35.htm
Old Nov 24, 2011 | 09:31 AM
bbs350z's Avatar
bbs350z
i think you were right. i recall something about that.
op theyre are 4 cam sensors out back, as well as positioning sensors up front on the front timing cover (blue and green plug). the de does not have these.
Old Nov 24, 2011 | 01:10 PM
Z_enthusiast
Those plugs are for rev up heads on a non rev up block/non rev up harness. Since I'll be doing a COMPLETE rev up swap I shouldn't have a problem given I use the rev up ecu/harness/re-program key fobs.
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
