Customer's 350z LS3 Swap
Old Jan 9, 2012 | 06:45 AM
John@z1's Avatar
John@z1
Z1 Motorsports
It should turn out to be a beast. Hope those wheels don't cause any danger.
Old Jan 9, 2012 | 11:05 AM
LuciaPwNs's Avatar
LuciaPwNs
sub'd. Your client seems serious about racing.
Old Jan 9, 2012 | 03:02 PM
mw9's Avatar
mw9
in for updates
Old Jan 10, 2012 | 08:31 AM
pwr2killayak's Avatar
pwr2killayak
ls3. HOLY JESUS. how many HP you lookin at once finished? looks awesome!!
Old Jan 12, 2012 | 06:56 AM
JE's Avatar
JE
Vendor - Former Vendor
He better be serious with a build like this!
To the wheels we should be looking at around 450.
Old Jan 14, 2012 | 10:59 AM
JE's Avatar
JE
Lingenfelter adapter plate and clutch.
Fits in there nice and snug.
Old Jan 14, 2012 | 11:05 AM
CRIDDA's Avatar
CRIDDA
Old Jan 14, 2012 | 12:30 PM
Cass007's Avatar
Cass007
Is that a stock intake and TB?
Also, slightly unrealted, but James may have an answer. I had an issue with my Cusco front sway contacting the pass side of the oil pan right at the corner on the weld bead. I assume this was from my lowered ride height (front wheels just inside the fenders) and stock endlinks.
If I purchased a beefy set of aftermarket links could I keep my aggressive ride height or is the answer just raising the ride height? I have swapped the stock struts back in for the time being to correct this issue. Thanks Guys.
Old Jan 14, 2012 | 01:14 PM
vq35deZ's Avatar
vq35deZ
my pants got shorter after seeing those pictures with the ls in the z
Old Jan 14, 2012 | 05:57 PM
STL 350Z's Avatar
STL 350Z
Hellooooo!
Sub'd
Old Jan 15, 2012 | 06:13 AM
Royal_T's Avatar
Royal_T
I swear I just love how these motors look in the Zs bay.. So clean
Old Jan 16, 2012 | 09:12 AM
JE's Avatar
JE
He's running the stock setup right now.
I don't have any direct experience with the Cusco bar. We run the SIKKY bars on our other cars and they have 3-way adjustment and heim joint endlinks. They are the perfect solution for low applications.
Here's a picture for you. You can zoom and see them pretty clear.
Old Jan 16, 2012 | 10:01 AM
JE's Avatar
JE
No, I did not post this in reverse order. Had to pull the drivetrain back out real quick to meet the customer's request. Ask and 'ye shall receive.
Old Jan 19, 2012 | 04:01 PM
Rambo's Avatar
Rambo
subbed let us know of any issues. I am building my motor for a swap. Great Build!!
Old Jan 19, 2012 | 04:18 PM
03threefiftyz's Avatar
03threefiftyz
Originally Posted by JE
After the cage obviously we will be adding weight, but close to 3,000 as possible is where we would like to be.
3000 isn't a problem. My car is sub 3,000 and still has all the plastics, dash, etc. No A/C or Radio, however.
Old Jan 20, 2012 | 08:39 AM
VO...'s Avatar
VO...
Administrator
Old Jan 23, 2012 | 12:15 PM
JE's Avatar
JE
Motor back in and awaiting a few more parts. Doing what we can as the parts flow.
Welded up the new shifter location
Customer wanted to run a carbon Braille battery so we made a base and mounted it up.
Old Jan 23, 2012 | 01:28 PM
  #38
Royal_T's Avatar
Royal_T
Looking good
Old Feb 18, 2012 | 09:37 AM
  #39
JE's Avatar
JE
Wow, time really goes by when we are this busy!
A lot of progress was made in the last few weeks when the remaining parts we needed arrived.
Custom SpeedHut tach to match the stock gauges. Once we get it outside I'll have a nice picture installed. Poor lighting in the shop for a justifying photo of it.
B&M Oil & Trans coolers mounted. Hard to snap some photos behind there, but hidden away is the custom mounted Mishimoto aluminum fan shroud and Koyo radiator. Had to fabricate some cooling lines and pipe to get everything to fit perfectly.
All routed, lined and support reinstalled. They fit perfect.
JE Pro Fab Custom intake system. John did phenominal work with the bends.
We will be relocating these AEM digital gauges to the pocket below with a custom bracket in the next week or so.
As soon as SIKKY Manufacturing delivered their bushing kit and aluminum driveshaft we were ready to knock out the rear of this car. We get excited to see these projects come together just like the customer does so we wasted no time pulling it out.
The entire shop smelled like burning rubber and a cat hoarders house for the day. Didn't get any pictures of the knocking/cutting process to remove the originals, but you get the idea.
After finishing the subframe installation the next step was to install the driveshaft and finish fabrication of the exhaust system. We were able to make custom midpipes to tie the SIKKY headers into the existing Greddy system.
The money shot.
And the last step before we move onto fabrication of the cage was to reweigh the car. We all were pretty amazed by how well the weight is distributed. After all the work we've done and everything involved in the swap it's at a perfect 50%. The car has about 8+ quarts of oil in it now, which added 20lbs; otherwise, we gained 0 weight overall and were able to have an almost perfect distribution. Just another reason why people bring us their cars. Our tech's performance and know-how speaks for itself.
Old Feb 18, 2012 | 10:38 AM
  #40
makdaddynuge's Avatar
makdaddynuge
wow! great work. That je pro fab intake is beautiful.
