ls6 350z build thread!
Old Jul 8, 2012 | 07:29 AM
  #181
04.350z's Avatar
04.350z
Old Jul 8, 2012 | 05:06 PM
  #182
NA&CH's Avatar
NA&CH
Berry berry Nice! Love the sound from the single.
Chris
Old Jul 8, 2012 | 06:32 PM
  #183
04.350z's Avatar
04.350z
Thanks
Old Jul 9, 2012 | 05:07 AM
  #184
Cass007's Avatar
Cass007
That is seriously going to mess with people's heads... ricer single exhaust with a big F-you V8 sound coming out of it
Nice to see its running. Almost there, keep at it.
Old Jul 9, 2012 | 08:05 AM
  #185
04.350z's Avatar
04.350z
Trying to keep the import look with a American heart
Old Jul 9, 2012 | 08:07 PM
  #186
A-Town-Z's Avatar
A-Town-Z
EPIC man. You sir, are a champ. I love the look/sound of the single as well. Incredible
Old Jul 10, 2012 | 03:46 AM
  #187
04.350z's Avatar
04.350z
I like the sound of.being called a champ
Old Jul 22, 2012 | 06:32 PM
  #188
04.350z's Avatar
04.350z
ok so heres my update the good bad and the ugly
not too many pics but here we go
finally got around to geeting the intake pipe made
a week ago we were finishing up the wiring for the coolant relay switch and accidentally shorted something out and fried the relay box.
got a new one ordered and luckily nothing else was toast other than the box.
coolant fans now come on and off on their own.
finally the tach was shipped to me.
didnt finish installing this tonight because we still need to run signal to the coolant gauge to get that to work and find the wire for the tach signal which is the pink wire on the ls6 harness i believe.
i sent my shifter back because it was not shifting in any forward gears.
sikky told me that when they recieved it it worked fine on their shopn vehicle which has a gto t56.
i have a ls1 camaro t56 personally i think there is more differences in these transmissions than just the shift linkage piece.
after they sent me back the shifter i reinstalled it, it would stay in 1st gear about 30% of the time it would not stay in 3-5 but R about 50% of the time. i am going to remove it again and attempt at modifiing it to get it to work properly
worst case i screw up a shifter that doesnt work and i have to order another junk shifter.
i did drive her today and she gets in in 1st and 2nd gears
the IAC hasnt learned properly yet and from time to time it would just off after throttle.
finally got all the heat wrap real hot and it stopped smoking
should be done with the finished product soon!
Old Jul 23, 2012 | 06:08 AM
  #189
Royal_T's Avatar
Royal_T
Looking good bro,,, Car sounds really good with the single exhaust..
Old Jul 23, 2012 | 10:34 AM
  #190
04.350z's Avatar
04.350z
Thanks and that's roughly what your new cam will sound like cause i have the same one
Old Jul 23, 2012 | 01:33 PM
  #191
bbs350z's Avatar
bbs350z
dude howd you wire up the fan relay?? i was gonna run mine to a switch, which i dont want to do
Old Jul 23, 2012 | 03:22 PM
  #192
graffkid732's Avatar
graffkid732
Sounds amazing. OMG
Old Jul 24, 2012 | 11:36 AM
  #193
04.350z's Avatar
04.350z
Secrets my friend lol. But just text me and ill walk you through it
Old Aug 12, 2012 | 03:37 PM
  #194
04.350z's Avatar
04.350z
well ladies and gentlemen i have a ground breaking yet devistating update.
I officially fixed the sikky shifter issue.
but that being said after speaking with sikky they said that doing this can void any warranty on the shifter.
ill post pics soon of how to fix the shifter.
so thats the ground breaking part.
on to the devastating part.
after fixing the shifter issue it was on to taking my lady on her maiden voyage.
she was running great. shifting properly with no over heating.
made it about five miles and decided to see what she had made a 1st gear pull slammed second and just before third gear a pop. and the engine stopped.
popped the clutch and nothing.
pulled into the gas station and filled it up with some gas before attempting at restarting.
tried to start her and had no sign of wanting to fire.
luckily a friend was following and we went and picked up my diesel and pulled the z back home.
we started pulling the front clip off and i decided to try and crank the engine by hand and i couldnt even get it to rotate at all.
a big uhhh ohh..
we will be pulling the heads off and tearing down the block tomarro.
when i will post picks of what we find along with the pics of how to fix the sikky shifter. stay tuned.
Old Aug 13, 2012 | 05:05 AM
  #195
Royal_T's Avatar
Royal_T
^^ oh man that sucks, good luck when opening up that motor. And thanks again for figuring out a way to fix the shifter.
Old Aug 13, 2012 | 05:31 PM
  #196
bbs350z's Avatar
bbs350z
good lord. nobody is having any luck with this stupid swap
Old Aug 13, 2012 | 06:29 PM
  #197
04.350z's Avatar
04.350z
so i got about half the motor torn down tonight. i have heavy gashes on all 8 pistons from the exhaust valves. i believe itsn from lack of clearance with the large cam.
i spun 3 rod bearings. due to the oil pump failing.
so i guess i need to finish tearing down the motor and rebuild for bigger and better things.
ill post poics tomarrow once full tear down is complete
Old Aug 14, 2012 | 01:45 PM
  #198
Brew_haha's Avatar
Brew_haha
holy crap so sad to hear! everyone is blowing their motors as soon as they get them in if you need any parts let me know
Old Aug 14, 2012 | 05:28 PM
  #199
04.350z's Avatar
04.350z
SIKKY shifter fix.
step 1 install ls1 shifter linkage block.
step 2 drill 4 new holes to match ls1 stock shifter position. *measure the center line and and drill accordingly* have a machine shop drill it so the measurements are correct.
step 3 make spacer plate to correct the lever length from the ls2 to ls1 shifter block. spacer plate should be 12g stainles steal.
step 4 install and drive.
heres a few picks of my damage.
too much valve lift.
3 bearings looking like this one welded itself to the crank.
oil pan full of metal shavings
Old Aug 14, 2012 | 08:24 PM
  #200
Brew_haha's Avatar
Brew_haha
Great write up on the fix and good pictures as well!!! Now fix their dip stick poping up issue
