ls6 350z build thread!
Old Jun 23, 2012 | 03:40 AM
  #161
04.350z's Avatar
04.350z
Started it up last night seemed to run fine
Old Jun 24, 2012 | 05:49 AM
  #162
04.350z's Avatar
04.350z
ok finnallly for a small update before she is finished.
so we came to the conclusion that the stock tach will not work the can bus system is going to be too hard to by pass.
but for some reason the speedo works not sure why or how accurate it is.
so im pretty positive i am going to pull all the gauges and run after market ones which i am not familiar with trying to get them to work any suggestions or opinions or part numbers are welcome.
i ran the car for about thirty seconds and seems to be ok idle is kinda high but i figured it would be considering new iac new computer etc. it will prolly have to learn a little bit.
but today i am buttoning up the whole system and hopefully driving it home.
also i popped it in first gear while on the jack stands and under any sort of throttle it kicks out of gear i think the detents might be bad. i want to try it again with it filled with fluid and see what happens .
but where is my update
utilized the stock z pedal
ran the line up through the firewall
headers were wrapped to prevent heat soak
ypipe that was made
upper radiator hose
enjoy ill be putting it all together today hopefully drving it home tonight
Old Jun 24, 2012 | 08:54 AM
  #163
Royal_T's Avatar
Royal_T
very nice bro... can't wait for vid clips..
Old Jun 24, 2012 | 05:18 PM
  #164
04.350z's Avatar
04.350z
i need a you tube account lol
Old Jun 25, 2012 | 06:06 AM
  #165
Brew_haha's Avatar
Brew_haha
Here is some info for you for the gauges. The stock speedo works because it runs off of the ABS system which still works if you even take out the stock ECU. All of the other signals you will need to get from the stock GM ECU or aftermarket sending units.
I would suggest a Stack gauge cluster or equivalent they will come with sending units and everything you need to install it.
Something i noticed in your pictures is that you have the FPR wrong. You dont need a vacuum like connected to the FPR. You just need to set it at 58 PSI and leave it. Unless you are running boost it will see the vacuum and raise the FPR higher than 58 PSI.
For the shifter...... If you are using a sikky short shifter then send it back that is your problem. They sent me a updated shifter and had the exact same problem with it. Told them even sent a video to justin and they ended up sending the exact shifter i sent back to them but with the "updated goods" They have had alot of problems with these shifters.
Old Jun 25, 2012 | 02:57 PM
  #166
04.350z's Avatar
04.350z
are you sure thats the issue ? i have been reading that the shift dents need to have more tension on them and that fixes the issue?
im on all data trying to figure out if i can fix it at home or not ill keep posted.
but if changing the tension doesnt help ill be calling sikky
Old Jun 25, 2012 | 10:40 PM
  #167
bbs350z's Avatar
bbs350z
^keep me updated. mine sits in gear fine. little tough goin in but nothing unusual. hope it wont pop out under load or ill be pissed.
Old Jun 26, 2012 | 05:41 AM
  #168
Brew_haha's Avatar
Brew_haha
Yea when they sent me my old shifter back with all of the "new improvements" it worked just fine but for how long only time will tell and is why im getting rid of the whole kit all together. Just wait till you get to the dip stick issue as well. It sees crank case pressure and will pop up out of the tube!
Old Jun 26, 2012 | 10:42 AM
  #169
bbs350z's Avatar
bbs350z
im gonna crimp it or weld on a thread port up top. wish i wouldve waited until now for this swap, wouldve been done overnight lol. and still no harness yet
Old Jun 26, 2012 | 11:47 AM
  #170
Brew_haha's Avatar
Brew_haha
I crimped it but still not a correct fix for the problem. Stop drinking for a week and you will have enough $ for a harness fool. and i can get one to you in two weeks if you need one.
Old Jun 26, 2012 | 02:27 PM
  #171
04.350z's Avatar
04.350z
crimp or weld? im confused?
Old Jun 26, 2012 | 06:06 PM
  #172
bbs350z's Avatar
bbs350z
i dont pay for my drinks sir! and justins got ahold of it again, he swore its be out, 2 weeks ago. still nothing. text me dude, i got a few misc plugs for custom things that might not be readily available to you guys.
either or
Old Jun 26, 2012 | 06:59 PM
  #173
04.350z's Avatar
04.350z
Crimp or weld what? Exactly
And i decided i am going to run the speedhut tach speed and fuel coolant combo. Is there info on the sizes? Link me!
Old Jun 27, 2012 | 05:20 AM
  #174
Brew_haha's Avatar
Brew_haha
you would just have to crimp the top of the dip stick itself to keep it from popping out
Old Jun 29, 2012 | 06:28 PM
  #175
04.350z's Avatar
04.350z
please help if anyone can let me know what size speed hut gauges work i want to replace the tach speedo and fuel / coolant
w/ speed hut tach , speedo, and fuel coolant combo
please help
Old Jun 30, 2012 | 04:24 PM
  #176
04.350z's Avatar
04.350z
good news i diagnosed tyhe issue with the trans kicking it out of gear and it is a shifter issue.
diagnosis steps
1 remove shifter
2 put it in gear
3 start up
4 let clutch out
after those steps it didnt kick out of gear so i believe it is a issue with the sikky shifter which is a bummer cause the shifter is so pretty but not fuunctional
will be having words with them on monday
Old Jul 6, 2012 | 04:11 AM
  #177
04.350z's Avatar
04.350z
Small quick update
The car moves
But ran into a few issues was finishing up the wiring for the coolant relay and something sparked and toasted my relay circuit board but a new one has been ordered.
Got the tachimeter ordered and the new circuit board ordered.
Was having issues with the sikky shifter it kicks out of gear under any sort of throttle so the requested i ship it back
So currently im in wait mode
Old Jul 6, 2012 | 06:56 AM
  #178
Cass007's Avatar
Cass007
please help
I think the speedhut link and info is in my thread somewhere.
Also, make sure you put a bead of some sort on your radiator hoses or you are daring them to pop off on you.
Old Jul 7, 2012 | 08:55 AM
  #179
04.350z's Avatar
04.350z
Those hoses are just for the test fit not permanent
Old Jul 8, 2012 | 07:27 AM
  #180
04.350z's Avatar
04.350z
video is being uploaded
