ls6 350z build thread!
Old Aug 14, 2012 | 09:02 PM
  #201
bbs350z's Avatar
bbs350z
Originally Posted by Brew_haha
Great write up on the fix and good pictures as well!!! Now fix their dip stick poping up issue
i just secured the mounting tab above the actual tube, onto the handle itself, and slightly bent the mouting tab and bolted it to my valvecover where the coilpack bolts onto. dimi is a genius, we know
Old Aug 15, 2012 | 12:05 AM
  #202
Brew_haha's Avatar
Brew_haha
i just got a pair of pliers and pinched it to the tube. Yea i win on that one, and dimi needs to get a running car before we dub him the genius title.
Old Aug 15, 2012 | 03:44 AM
  #203
04.350z's Avatar
04.350z
To fix the issue on that end. I believe if you take the plug on the drivers. Side valve cover out and you install a breather you should be fine.
Old Aug 15, 2012 | 05:18 AM
  #204
Royal_T's Avatar
Royal_T
Nice and easy fix right there 04.350z. Thanks for the write up and man that really sucks about the engine.
Also do you know what the spec is for that plug on the driver side if we want to put a breather there
Old Aug 15, 2012 | 12:43 PM
  #205
04.350z's Avatar
04.350z
I try to keep it simple i though to myself when figuring out the problem what can i do to make this more to oem spec and this is what i came up with lol.
As far as the breather no idea.
I gotta figure out what to do next for my motor rebuild for stock or stroke her out for boost
Old Aug 16, 2012 | 08:31 AM
  #206
Brew_haha's Avatar
Brew_haha
breathers didnt work for me when i tried them
Old Oct 21, 2012 | 08:01 AM
  #207
04.350z's Avatar
04.350z
Sorry for the lack of updates on my thread.
turns out i destroyed 3 rods on the process.
Got my motor back last week from Hedricks Precision Engines.
Replaced 3 rods
replaced piston rings
all new rod bearings
all new cam bearings
all new main bearings
honed cylinder walls
hot tanked the block heads and pan.
new lifters
and new valve spring locators.
the reason for the new locators was because TSP did not provide them with their kit. they said their kit was a direct install. which apparently isnt true. installed height for the valve spring they provided is 157lbs at inch 800. mine was at 202lbs at inch 800.whcih was fine for the 6 miles i drove the car before she blew up but would have eventually destroyed my heads. BEWARE! make sure and measure your installed height!
in between all this i have been moving into a new home. the z now has a 2.5 car garage all to her self.
this weekend i installed all front accesories, clutch and flywheel, transmission and most of the wiring harness. I would post pictures but its nothing you guys havent seen previously in my thread.
all thats left is to put her all back together which will hopefully be next weekend.
only thing left to buy is a oil pressure gauge that will be accurate with the ls6 sensor. any suggestions?
thanks,
enjoy
Old Oct 25, 2012 | 08:33 AM
  #208
QuintonC's Avatar
QuintonC
Awesome thread, I really enjoyed reading this build. Best of luck when it's back together, sounds mean with that single. Do you have a total build price if you don't mind me asking?
Old Oct 26, 2012 | 06:13 PM
  #209
04.350z's Avatar
04.350z
no i dont but at minimum a ls build with be around 10k and thats bare minimum with me doing all the work wiring etc id put mine right around 14k right now.
Old Oct 28, 2012 | 11:07 AM
  #210
coanan's Avatar
coanan
Oil pump failers are very rare; the most common reason for no or very low oil pressure on a LS build is reusing the old pickup tube O-ring or pinching the new one when installing the tube into the oil pump. Be very careful with this new build and have an oil pressure gauge working when you start it.
Old Oct 28, 2012 | 12:31 PM
  #211
The_Laughing_Man's Avatar
The_Laughing_Man
I hope my oil pump never fails.
Old Dec 17, 2012 | 04:51 AM
  #212
04.350z's Avatar
04.350z
car is finished. and running/ drivable.
still needs to be tuned because i am running a map only setup runs but mildly rough.
i have a coolant leak from my water pump which is an extremely easy fix but i am lazy so it will get done over the winter.
ill be taking it to topuge factory in chicago. just to have a full inspection done everything ran though just to make sure she is ready for the track next year.
after they finish the inspection ill be dropping it off at speed inc also in the chicago area to tune her up.
im glad this bastard child is finished.
even though i kinda want to sell the z now and build something else.
Old Dec 17, 2012 | 05:37 AM
  #213
Z33Garage's Avatar
Z33Garage
car sounds like sex
Old Dec 17, 2012 | 12:03 PM
  #214
Royal_T's Avatar
Royal_T
vid please
Old Dec 17, 2012 | 01:47 PM
  #215
04.350z's Avatar
04.350z
Ill get one soon E im currently in indy for work when i get back ill be sure to do that just for you lol
Know anyone that wants to buy a ls swapped z? Cause i got one
Old Dec 17, 2012 | 05:21 PM
  #216
Classy's Avatar
Classy
Trade you an 09 challenger R/T with a 6 speed in hemi orange
Old Dec 17, 2012 | 05:53 PM
  #217
04.350z's Avatar
04.350z
Pass wanting to go.back.the import route motor wise smooth torque wasnt for me. Not happy with the swap. Its a good swap just isn't what i was looking.for i guess. Or maybe Im just over this car after i blew her up.once.
Old Dec 18, 2012 | 01:46 PM
  #218
QTB's Avatar
QTB
These are little baby springs
My seat pressure were set to 250-255 lbs and I have about 0.660 lift with 850 lb/in springs
Can't wait to see it up and running at the track!
Old Dec 18, 2012 | 05:42 PM
  #219
04.350z's Avatar
04.350z
Trying to get it up to get tuned soon and the final look over before track time if i keep it
Old Dec 18, 2012 | 06:54 PM
  #220
QuintonC's Avatar
QuintonC
Indy eh?
