Rambo's LS6 G35 Build
Old Feb 20, 2012 | 06:37 PM
Quamen's Avatar
Quamen
Originally Posted by Rambo
Just purchased an EPS 226 INT./230 EXT. .600 lift custom cam today....2 weeks and counting until I get it!!
That should be a nice cam!
Old Feb 20, 2012 | 07:18 PM
Rambo's Avatar
Rambo
Yeah talked with goeff from EPS today for a while today and went back and forth between the 222/226 or the 226/230. I ended up with the 226/230 and hoping I can find someone good down here in ohio to tune my motor.
Old Feb 21, 2012 | 06:41 AM
Brew_haha's Avatar
Brew_haha
searched and no username ^^^^^^????
Old Feb 21, 2012 | 06:45 AM
phreaktor's Avatar
phreaktor
Design Engineer
*thinking about selling a kidney
Old Feb 21, 2012 | 07:21 AM
taywan's Avatar
taywan
this is going to be baddazz!!!
GL with it all!!
Old Feb 21, 2012 | 08:05 AM
bbs350z's Avatar
bbs350z
ill take it *raises card*
Old Feb 21, 2012 | 08:53 AM
Brew_haha's Avatar
Brew_haha
i need a liver and a set of lung while your at it
Old Feb 21, 2012 | 12:27 PM
bbs350z's Avatar
bbs350z
your gonna need those after zdayz thats for sure lol, bringing a drum of jaeger muahahaha.
Old Feb 25, 2012 | 09:51 AM
Royal_T's Avatar
Royal_T
Man I love this build, especially since you are building from the ground up.. Love the engine color
Old Feb 26, 2012 | 10:42 AM
Rambo's Avatar
Rambo
Its Geoff on LS1tech for EPS engine power systems. My sn on LS1tech is GNIUS (my license plate no)
Thanks. I actually have learned alot from your build thread!! (Actually the one that made me make the plunge for the motor build!!!) Format is borrowed as well.
My goal for this thread is to document the build and track total cost so everyone can get a good number for a mild engine build and swap.
Old Feb 27, 2012 | 07:08 AM
Royal_T's Avatar
Royal_T
Oh man thanks for the kind words. Glad to help motivate you in starting this build.. Can't wait to see it done..
Old Feb 28, 2012 | 07:09 PM
Rambo's Avatar
Rambo
Just ordered a new cam retainer plate, ARP cam bolts, rear main seal, rear gasket, LS2 cam gear, and C5R timing chain. Should be enough to complete the rotating and timing assembly.
Old Mar 15, 2012 | 03:22 PM
Rambo's Avatar
Rambo
All my timing components in!! And my E40 ecm!! I am going to install them this weekend.
C5R Timing Chain and Crank Turning Tool (This is a godsend!!)
Custom ground EPS 226/230 .600" lift cam.
Old Mar 17, 2012 | 01:07 PM
Rambo's Avatar
Rambo
Time for an update. Got the timing stuff all installed!!
The new cam, all lubed up and only one place to go...
It went in so good!!
Rear Seal and Rear Cover are in!!
I was interrupted by the mail man. He had a present for me!! Timing chain damper came in!!
Cam retainer plate is in and I drilled and tapped the block for the new timing chain damper!!
Cam timing mocked up. Dot to dot. Pretty simple.
Timing gear, C5R chain, and timing chain damper installed!!
All done for today. Short block is almost done!! Just need an oil pump and front cover.
Old Mar 18, 2012 | 05:52 PM
Cass007's Avatar
Cass007
Great Progress. Keep at it!!
Old Mar 18, 2012 | 06:05 PM
1991ls13's Avatar
1991ls13
Hey man, nice build so far.
I did a ls6 in my 240sx a couple years back and just spent a sh** load cause i bought most everything for direct bolt on. Engine mount etc and everything.
Are you going to fab or buy a kit to put in. Cause i`d love to learn the specs etc from your build to do my 04z, thinkin on an ls3 instead of just turboing`rear if i did` cause i love relibablilty and not always having to mess with vacuum leaks etc.
Thanks
ps, if you want with as a DD, dont get anything bigger the a tv2, cam specs 232-234, it was just a smig to big for dailying it. I`d go for something just a bit smaller
edit: Saw your specs... Perfect, I`m sure you`ll love that size cam
Old Mar 19, 2012 | 02:32 PM
Rambo's Avatar
Rambo
Thanks man!! I am going to order a mellings oil pump and front cover here shortly to finish the short block...inching the the finish line. From the calculations on my cost tracking spreadsheet that I am keeping, I am 62.12% done with my motor build right now.
Thanks
I think I am going to buy the Fueled Racing mount system as I dont want to have an enormous amount of down time fabricating parts. Unless anyone has blueprints of mounts and cross members that I could copy.
I spent alot of time researching those cam specs (and every other part, balancing cost and goals) and talking with vendors on LS1tech. I am excited to see how it will drive, but it will now come down to how good the tune is.
As for the LS3, it depends on how much you want to spend for a block. An ls3 would be easily 5k for a used motor. I did the LS6 because I got the block and about $400 bucks. If i ever built another new one of these I would get an LS2 bare block and stroke it. parts for the ls3 and ls7 are still expensive imo.
If you want to know all my specs and parts list I am going to keep the first post updated as best as possible and I have a running parts list in a spread sheet if anyone is interested. Just PM if you want it.
Old Mar 21, 2012 | 07:58 AM
  #38
Brew_haha's Avatar
Brew_haha
As for the LS3, it depends on how much you want to spend for a block. An ls3 would be easily 5k for a used motor. I did the LS6 because I got the block and about $400 bucks. If i ever built another new one of these I would get an LS2 bare block and stroke it. parts for the ls2 and ls7 are still expensive imo.
If you need any prices feel free to PM me about any of the swap kits
Old Apr 13, 2012 | 06:36 PM
  #39
MDHRZ's Avatar
MDHRZ
Looking good so far. Anxious to see the finished product.
Old Apr 14, 2012 | 06:39 AM
  #40
Royal_T's Avatar
Royal_T
Very nice update, Question where did you buy the Timing chain damper from?
