Is this an 03 or 04 transmission?
Old Apr 3, 2012 | 11:55 AM
04DaytonaZee's Avatar
04DaytonaZee
Default Is this an 03 or 04 transmission?
It's out of our 2004 Touring, I even purchased the CZP 04-06 ball stud replacement and when we popped it apart we found this. WTF...
That looks like a stock 03 ball stud. How can this be? 120K on engine/trans.
Old Apr 3, 2012 | 12:33 PM
JCat's Avatar
JCat
I can't answer your question, but if it is a manual tranny, make sure it is model or release #9. (CD 009) If you use anything else, you are wasting your time.
Old Apr 3, 2012 | 01:57 PM
04DaytonaZee
It is a CD # 001
122,000 miles on it, fresh GL4 syntorc 75w-85 and only issue is grind into 5th gear if you don't shift slow.
Old Apr 3, 2012 | 03:38 PM
sportbiketed's Avatar
sportbiketed
lol that transmission is f*cked
Old Apr 3, 2012 | 06:05 PM
04DaytonaZee
Why do you say that?
Old Apr 4, 2012 | 04:48 AM
JCat's Avatar
JCat
Nissan 350Z manual transmission model numbers CD001 - CD008 have an inclination to fail. The CD009 is the most desired model.
If you search any 350Z forum internet site for "transmission" or "CD009" you will get many threads that explain it further.
Old Apr 4, 2012 | 06:12 AM
lbarge85's Avatar
lbarge85
Definitely an '04 trans based on VIN plate
Old Apr 4, 2012 | 09:31 AM
bheaver's Avatar
bheaver
I just went through the same thing with my 04 transmission. 5th gear grind except when shifting slowly. You can re-build or replace, after a lot of research I chose to replace with a CD009 I bought off a member here.
Old Apr 4, 2012 | 12:39 PM
djamps's Avatar
djamps
All of them have #1 stamped on them. You can only tell if it's a CD009 by a sticker. My '04.5 came with a CD008 BTW.
Old Apr 4, 2012 | 12:51 PM
Cass007's Avatar
Cass007
2005 was the first year for the 009 I believe and djamps is correct in saying that the sticker will list what version it is.
Old Apr 4, 2012 | 10:37 PM
04DaytonaZee
Well darn. I couldn't tell you guys what transmission this is then cause the sticker's print has been rubbed clear off at this point in the vehicle's life.
Transmission has 122,000 on it. We just installed Exedy OEM clutch kit with jwt flywheel. 75w-85 syntorc gear oil. Shifts well (slightly notchy (Edit: Sometimes)) through all gears, but fights back when throwing it into 5th from any other gear when rpm's are higher than about 2500. Car drives beautifully otherwise. I think we will drive it the way it is till further issues occur.
Old May 25, 2012 | 10:23 AM
StraySheep's Avatar
StraySheep
My 2006 Z with 74,000 miles is now finally having this infamous 5th gear grind.
I didn't check which transmission model it has, but I am gussing it should be CD009.
The 5th gear was never abused and only used during normal street driving.
So I believe this 5th gear grind will eventually happen to Z & G35 with 6MT transmission.
Cross your fingers if you don't have the 5th gear grind yet.
Old Aug 9, 2012 | 03:37 PM
SeXy RiDe's Avatar
SeXy RiDe
where would the sticker be located if it is a cd009. just got a transmission installed they were suppose to put in the cd009 but i want to make sure. is there any difference when looking at the stock 03 trans compared to the cd009 trans from under the car??
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
Row2K
North East Marketplace
Dec 27, 2015 12:09 PM
