Just another 600Z Magnum
Old May 9, 2012 | 07:27 PM
  #41
supraturboman's Avatar
supraturboman
Originally Posted by Cass007
This seems impossible... that setup is usually going for ~$6K. Besides, in your FI thread you said you already had your LS motor.
Yes. I bought the motor. It was a buddies. it was out of his GTO.
Old May 31, 2012 | 01:14 PM
  #42
Langdonious Rex's Avatar
Langdonious Rex
Updates? You need a new block?
Old Jun 1, 2012 | 06:52 AM
  #43
QTB's Avatar
QTB
I just tore the motor down last night. There is a crack around the alignment pin from the block to the head on both the inner and outter part of the block going to the water jacket. I'm by no means a block repair expert but I don't think it's fixable. To weld it up you'd have to cut out a major section of the block, weld the inside crack and then weld the major section back in. There's a lot of room for things to go wrong.
The next task is to figure out why there's a crack there.
Old Jun 1, 2012 | 08:17 AM
  #44
Langdonious Rex
Good luck finding the cause of the crack. Don't want to be repeating that
I have a LS2 longblock I'm looking at parting out, if you're interested.
Old Jun 1, 2012 | 08:50 AM
  #45
Junkster's Avatar
Junkster
Sorry to hear about the crack! that blows...sad to see projects come to a hault over something so stupid
Definately sub'ing for future updates, rock on!
Old Jun 29, 2012 | 05:21 AM
  #46
QTB's Avatar
QTB
Couple small updates...
I have just got new LS3 valves for my heads, they're about 20g lighter per intake valve than what I have.
I am looking high and low for a forged crank and cannot find one with the 3.622 stroke....so I'm stuck there for now.
Old Aug 3, 2012 | 08:26 AM
  #47
QTB's Avatar
QTB
The heads are rebuilt and even got a little porting done to them! I've also got an entire short block (in pieces) ordered....
GM LS2 block
K1 Tech crank (stock stroke, 51 lbs)
K1 Chevy Supreme rods (507grams and rated for 7600 rpms)
Mahle pistons 398 grams, 4.000 bore, -4cc vol., (lightest I could find)
ARP main studs, all new gaskets, Clevite bearings, blah blah blah.
Hopefully by the end of Sept I can have something close to running.
Cheers!
Old Sep 26, 2012 | 09:07 AM
  #48
QTB's Avatar
QTB
Looky looky!
I degreed the cam last night and checked PTV. I'm just waiting on all the block plugs to finish sealing it up then she goes back in. Hopefully much more easily since I've done most of the other work with the first engine.
Old Sep 26, 2012 | 09:11 AM
  #49
VO...'s Avatar
VO...
Administrator
Looking good...
Old Sep 26, 2012 | 02:21 PM
  #50
QTB's Avatar
QTB
FML I can't win. Rockers are hitting the valve covers now...
Old Sep 26, 2012 | 02:36 PM
  #51
bimmertech's Avatar
bimmertech
just open that wallet back up
Old Sep 28, 2012 | 06:47 AM
  #52
QTB's Avatar
QTB
Well I didn't open the wallet but I opened the baffels with a die grinder. Then I cleaned the hell out of them. I'm let them sit over night and I'll test fit them tonight and see how it looks. Otherwise it needs the oil pan on and it's basically ready to go back in...again....again. Okay it's been in and out probabaly 20 times, fine I said it!
Old Sep 28, 2012 | 05:47 PM
  #53
freddys 350z's Avatar
freddys 350z
nice build
Old Sep 29, 2012 | 01:58 AM
  #54
stascom's Avatar
stascom
Stay strong
Old Sep 29, 2012 | 10:08 AM
  #55
STL 350Z's Avatar
STL 350Z
Sub'd
Old Oct 1, 2012 | 05:36 AM
  #56
QTB's Avatar
QTB
Well I didn't get as much done over the weekend as I hoped but I now have the engine back in the car and the drive shaft bolted up. I did forget to put the plug into the dipstick hole in the block. So I need to run one of those down tonight. Aside from a few wiring things and some minor heat shielding the rest should go pretty fast.
Old Oct 7, 2012 | 01:06 PM
  #57
QTB's Avatar
QTB
Well more car drama and progress. Tried to bleed the slave cylinders and it was leaking. Pulled it apart to find the CSC was cracked, brand new too. So that's on order and should be here this week with any luck.
I also noticed the crank pulley is chipped so I am getting a ATI super damper on order as well. Since I am waiting on parts today I decided to work on some other areas of the car.
APR 3" studs and Ti Lugs.
SPL front bushings,
Old Oct 12, 2012 | 05:08 AM
  #58
QTB's Avatar
QTB
I finally got my second new CSC, put it in and it's leaking too. It appears that this one is leaking from the fittings. It was getting late so I called it quits for the night so I'll pull it apart again tonight and see what's actually going on.
On a positive note the bushings have been pressed and are back in the car and I think the new harmonic balancer should be in tonight. So pending yet another disaster I'm just stuck on this damn CSC.
Old Oct 12, 2012 | 05:47 AM
  #59
kramykram's Avatar
kramykram
omg man lol you have very good patience. i would of done smashed my windshield out. But your build like the rest on here is awesome. Love the v8 sound out of our cars.
Old Oct 12, 2012 | 07:16 AM
  #60
Quamen's Avatar
Quamen
Keep plugging away at it bro! Ever is the constant struggle of performance cars...
