Larger oil filter, more oil ???
Old Jan 7, 2004 | 11:59 AM
maximumsport's Avatar
maximumsport
Default Larger oil filter, more oil ???
I know the stock oil filter is short and stubby, but I've been reading ppl using the longer filter, what I need to know is would you have to use more than 5 qt of oil ??
Old Jan 7, 2004 | 12:30 PM
G35SC T.T.'s Avatar
G35SC T.T.
motor plus filter only like 4 1/4 or so quarts
Old Jan 7, 2004 | 03:07 PM
Trustym's Avatar
Trustym
I think it would still be the 5 quarts that's in the manual.
Old Jan 7, 2004 | 04:38 PM
lowrider's Avatar
lowrider
I use a larger filter, a K&N HP1006 vs. the stock size HP1008. I talked to a K&N tech, and he said it had the same specs, only larger. It still holds 5 qts. however.
Lou
Old Jan 7, 2004 | 04:57 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I got the "big" OEM filter today from Nissan....7000 intercals my butt! This is smallest OEM filter I have ever seen!
Old Jan 7, 2004 | 05:45 PM
FLY BY Z's Avatar
FLY BY Z
if you think the 9E is small you should see the 9. the 9 is what is stock on our car. then you can have a new personal record.
Old Jan 8, 2004 | 06:08 AM
Audito350Z's Avatar
Audito350Z
if you want to carry more oil, you should consider a larger oil pan. There were posts recently about an aftermarket pan, not sure who was making it. I think it gets you up to about 6 or 7 quarts of oil.
Another way to run a tad more oil is to install a remote mount oil cooler. Nick at ntechengineering.com is working on one right now and should have it to market soon. You might be able to run abuot a half-quart more oil... plus you will keep your oil cooler.
Hope that helps....
PeteH
Old Jan 8, 2004 | 06:20 AM
Eagle1's Avatar
Eagle1
Default oil filter
There are numerous excellent threads on oil and filters that you can dig up here and on freshalloy and g35driver that go into real detail on oil and filters. So this will just summarize.
Basically, consider going to a Purolator Pure One or Mobil 1 filter instead of the stock, because they have metal and not cardboard endcaps. I use the larger M110 filter, a touch bigger than the stock size match M108. Both available at Autozone. They are still shockingly small compared to what we may have been used to with cars of the 60's vintage, and you do not need to use more oil than the standard 5 quarts on the change.
If you want to get really filter fanatic, take a look at the Amsoil bypass dual filter set up. Takes out particles smaller than one micron. Testimony about getting 500,000 miles on an engine and then tearing it down, only to find wear equivalent to typical 80,000 miles. I don't think many of us are going to keep this car for that kind of time or use, and the application is better for big long haul trucks and "keeper" equipment like tractors and loaders. But it is an interesting read and educational, at www.amsoil.com
Good luck.
Old Jan 8, 2004 | 08:32 AM
maximumsportZ's Avatar
maximumsportZ
Thanks alot guys for your help I went and got the OEM 9E filter.
I'll try that mobil 1 filter next time.
great info guys thanks!
Old Jan 8, 2004 | 10:45 AM
BluZee's Avatar
BluZee
The OEM filter is actually a 65F. It is smaller than the 9E though.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
