spark plug access
Old Jan 13, 2004 | 06:22 PM
philsill350z's Avatar
philsill350z
Default spark plug access
how do i access my spark plugs to change them?
Old Jan 13, 2004 | 06:36 PM
daking350's Avatar
daking350
very easy...heres a pic..Remove the 10mm bolts holding each coil..# on each side..pic 1 is drivers side#1 and pic 2 is passenger side #5...You will need a sparkplug socket and a 6-8"extension..
Old Jan 13, 2004 | 06:38 PM
daking350's Avatar
daking350
make sure you go 1 degree cooler plug..preferably the NGK LFR6A-11 from sparkplugs.com..
Old Jan 13, 2004 | 08:07 PM
apex locator's Avatar
apex locator
dont forget to put a little anti-seize on the plugs
Old Mar 9, 2004 | 06:35 AM
Enron Exec's Avatar
Enron Exec
How long did it take you to change out all the plugs? I think my dealer is screwing me and charging $236 for what seems a simple install.
Old Mar 9, 2004 | 09:19 AM
apex locator
took me about an hour because i had to move so many wires/hoses around to access the plugs
and i had to remove my intake tube also
pretty straight-forward, just a little time-consuming.
Old Mar 10, 2004 | 12:46 PM
ZilvahZ's Avatar
ZilvahZ
You know there was two things that drove me crazy on the Z.. 1. finding out there were no spark plug wires and 2. haveing to search for the plugs that aren't visable to the nekkid eye!
Guys..thanks for uncovering them and "showing me the way"! I'm planning on a cheap mod by switching over to iridium plugs too. Heard nothing but great things about them! Oh, and BTW they're NGK LFR6A-11's
Old Mar 10, 2004 | 02:11 PM
VR3's Avatar
VR3
How many good miles can we expect to get out of the stock plugs?
Old Mar 10, 2004 | 02:17 PM
ZilvahZ's Avatar
ZilvahZ
The stock plugs are platinum plugs as I recall. I think the owners manual requires replacement at 105K miles. (Heh..I'm not waiting that long to change mine out..) I have about 16,500 give or take a few.. I understand the new plugs give a little more HP at the rear wheels as well as smoother idles. So why not?
Old Mar 10, 2004 | 06:25 PM
infidsg35's Avatar
infidsg35
Ok im not scared to change my PLUGS!!!! Iv been reading of 2 diffrent cars that are having problems due to bad plug install... Even the deal goofed on it!!! When I get my SCer I need to change to one step colder plugs and a gap of about .30 - .39 can I drive on this setting? What is anti-seize??
Thanx
Old Mar 11, 2004 | 04:41 AM
j's350z's Avatar
j's350z
The LFR6A plug is not iridium, it is a standard plug just 1 degree colder... I swapped mine a few weeks ago at 40,000 miles and they made a big difference. Also the stock gaps were all over the place, anywhere from .040-.050....... There is no way I would wait 100,000 before changing the plugs... Also, anti-seize is a grease that should be put on the plug threads whenever installing new plugs so you can change them again in the future. It protects the threads against heat and water .... You also want to put some dialetric grease in the plug boots.....
Jason
www.racemrc.com
Old Mar 11, 2004 | 05:17 AM
ZilvahZ's Avatar
ZilvahZ
Thanks j's350z, I think the correct iridium plug numbers is OE Laser Iridium LFR5AIX-11 with a gap of 0.044. Don't know if this is a colder plug or not?
Old Feb 3, 2006 | 10:14 AM
sq40's Avatar
sq40
Tag.. Any Place Cheaper than $7.50 Each on the LFR5AIX-11s?
Old Feb 3, 2006 | 05:26 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
It would not suprise me if the dealer charged $230 to change the plugs. It probably books out to a 2.5-3.0 hour job. But realistically, it can be done in under 1 hour.
If anyone needs 1 step colder NGK Iridiums for FI/Nitrous cars, we always carry about 30-40 sets in stock. Click here: http://www.forgedinternals.com/store...cat=264&page=1
Old Feb 5, 2006 | 10:42 PM
veilside350zTT's Avatar
veilside350zTT
that price on ur site is for all 6 plugs correct? and wat is shipping?
Old Feb 6, 2006 | 06:07 AM
Sharif@Forged
Forged Performance
That's correct: 6 NGK Iridium 1 step colder plugs, and shipping is included.
Old Feb 6, 2006 | 08:32 AM
dgz32's Avatar
dgz32
Be sure to use inch/lbs rather then foot/lbs when installing the new plugs as well.
Old Feb 6, 2006 | 09:58 PM
veilside350zTT
Cool sharif i ordered my plugs just now.. So they should come pre gapped and ready to go correct?
Old Feb 7, 2006 | 06:57 AM
Sharif@Forged
Forged Performance
Your order has been processed. Yup, just double check the gaps, but they should be around .040-.044, and ready to go. We dont gap FI plugs down, becuase Nissan's coil over plug ignition system is very robust, and I havent seen spark blow out...even beyond 600whp+.
burglapfd
Dec 6, 2020 01:04 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
35reilly
Sep 28, 2015 07:42 AM
