New JDM HKS ST Build but what are these parts ?
Old Dec 15, 2012 | 07:37 PM
R6n350GT's Avatar
R6n350GT
Default New JDM HKS ST Build but what are these parts ?
So engine builder only had enough time to pull engine out of car, build new one but i have to put it all back in...
Pics of Engine
Now i get given my car back no engine or any parts inside the bay, and a box of bolts... great, where do these all go..
I found this tread so it will help somewhat but appreciate if anyone can identify and let me know and i can then figure out the rest hopefully!!!!
http://g35driver.com/forums/engine-d...olt-sizes.html
Thanks very much, i appreciate it !
Old Dec 15, 2012 | 08:24 PM
ocdz's Avatar
ocdz
31&32 are battery tie downs
Old Dec 15, 2012 | 09:27 PM
Guilty1s's Avatar
Guilty1s
I have played this game before.
Should have 8 of the same length for those VTC solenoids. Id guess 24
six of them for the coil packs. M8 bolts
36 is Evap solenoid
38 is a bracket for the harness
27&29 belong to the center idler pulley.
You can elimate a lot by putting on your alt & PS. All with m12 bolts ie 11,27,&28
44 is coolant lines for oil filter housing/cooler. There is also a hardline that is between them that runs under the crank
25 kinda looks like driveshaft bolts... idk
34 looks so familiar... only thing I can think of is the spring in the shifter though.
41 is a radiator hose
42&43 are vacuum lines. You have/had an Evap vacuum, a line that runs from the PCV to the plenum, and the back of the drivers side VC to ... near the throttle body?? IIRC
There is also a U shaped hose that runs between the 2 VC by the timing case
39 is probably motor mount bolts
looks like there is a few more for then upper plenum. either 10 or 12. You can tell when they are in there....they will all be spaced equally even though there is 2 lengths.
Your harness is held on my a few m8 short bolts.
Old Dec 15, 2012 | 09:47 PM
R6n350GT's Avatar
R6n350GT
^^ I am updating what i have found, ill add yours to my list in a sec, thanks so much!!!
edit: wow you are awesome, btw ps, alternator, a/c are all still on old engine so no brackets, bolts/nuts should be in that pic.
trans and drive shaft also taken out
Engine didnt come with coil packs
(I brought this engine a year ago and it didnt have a few bits and pieces which im taking off my un-built engine fyi)
red = Guilty1s
green = friend of mine
Just incase it helps someone here is some of the ones i figured out
1: ?
2: ?
3: ?
4: ?
5: ?
6: Sump plate
7: ?
8: ?
9: ?
11: Coolant cross over
12: Plenum inner
13: Front of the under body splash guard
14: ?
15:?
16: ?
17: ?
18: Sump
18: ?
20: driving lights nuts
21: driving light spacers
22: ?
23: ?
24: Plenum outer
25: Tail shaft
26: ?
27: Idler Pulley
28: upper bell housing
29: lower bell housing
31 & 32: Battery bracket
33a: ?
33b: lower 4 are for that front black radiator support bracket
34: Shifter spring
35: Coolant cross over bracket (attached to timing chain cover)
36: Evap solenoid
37: to cover the lower left bell housing hole (opposite side of alternator, as its RHD)
38: Harness bracket (where does this attach to?)
39: Engine mount nuts
40: ?
41: Radiator hose
42 & 43: Vaccume lines
44: coolant lines for oil filter housing/cooler
44: cam cover breather hose?
Any other help would be awesome
Old Dec 16, 2012 | 02:52 PM
Nathan's Avatar
Nathan
Where about in Queensland are you ? I'm on the Nth side of the Gold Coast. You can take a good look at my car if your close by. Really need to take a good look & photos under the hood for all those small hoses & brackets
Old Dec 16, 2012 | 03:11 PM
350z006's Avatar
350z006
40. Nuts to hold front of plastic engine cover down
Old Dec 17, 2012 | 02:20 AM
MR RIZK's Avatar
MR RIZK
FYI: The turbo cool side is rotated incorrectly. If this is a new kit not sure why this has been clocked in the wrong position.
Old Dec 17, 2012 | 02:29 AM
Simon da Silva's Avatar
Simon da Silva
OT: Can you still get the HKS ST turbo kit? and GL with all the bolts
Old Dec 17, 2012 | 03:12 AM
R6n350GT's Avatar
R6n350GT
I'm at varsity man and my names Nathan as well , what are the chances !!
And he is/shouldn't be a friend of mine that built it, been a real dick and just bad ethics .. Made me wait 3months and he only finished it cause I said I'd do the rest... Never again will I ask him... I paid him as much as a shop too..
And wow can't believe he installed it wrong. . He Is the type to know it all and not loOk at instructions. Wouldn't even lend me a stand or even the bolts when I brought my own stand
Old Dec 17, 2012 | 04:01 AM
MR RIZK's Avatar
MR RIZK
nope
May 30, 2017 03:28 PM
_bit
Oct 2, 2015 07:49 AM
