Clutch replacement
Old Jan 21, 2013 | 05:52 PM
Protege's Avatar
Protege
Default Clutch replacement
Hey there!
My clutch finally crapped out on me and I am looking to replace the whole thing, I do not currently have the resources or time to do this replacement by myself, but I am making this post in regards to what you guys think my upgrade should be?
I've heard good things about the JWT 350Z Clutch/Flywheel Combo, 03-06
as well as the ACT clutch kits.
I was curious if you guys agree with is the best upgrade in it's price range?
The repair will run me about ~$650-$700 with no warranty. The car is a semi-daily driver and occasionally tracked.
Kind regards,
Prodigy
Old Jan 21, 2013 | 07:10 PM
Protege's Avatar
Protege
additionally, I am having synchro problems with the trans. Should I fix this 100% as I have read that the jwt can cause further synchro problems.
Thanks guys
Old Jan 23, 2013 | 09:09 PM
RENFRO's Avatar
RENFRO
I'm on the same page with the synchro issue. If you're going to bother dropping the trans to put in a clutch, put in a CD009 tranny.
My plan is to swap out to the CD009 and the JWT Clutch/Flywheel all at once
Old Jan 27, 2013 | 07:11 PM
Protege's Avatar
Protege
I wanted to do the same, unfortunately I don't have the funds for a new trans at the current moment!
The mechanic is going to check my synchro as well tho.
I'll let you know how I like the jwt, its sitting here behind me!
Old Jan 27, 2013 | 07:50 PM
dkmura's Avatar
dkmura
General & DIY Moderator
You might also try refilling your tranny with Redline MT85. It's a synthetic lubricant engineered with enough friction to help syncros work well. A relatively cheap, but effective, solution for gearboxes.
07ZEKE
Aug 23, 2021 09:15 PM
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
