Camshaft recommendations
Old Mar 22, 2013 | 03:22 AM
RodiZio's Avatar
RodiZio
Default Camshaft recommendations
What's a good cam for my turbo build? What about Nismo 99996-S1CK cams?
Old Mar 22, 2013 | 12:26 PM
JCITY's Avatar
JCITY
Obviously by the lack of responses to your question,cam installs
are not something the average Z owner does.My car is N/A.I'm
running a Nismo R tune cam set.For what its worth,I'm very
pleased with the performance.
Old Mar 22, 2013 | 12:33 PM
str8dum1's Avatar
str8dum1
no one knows what your turbo build is, so no one can recommend any cams.
Old Mar 22, 2013 | 12:55 PM
eltness350's Avatar
eltness350
The Untouchable
i have the brian crower stage 2 cams if that helps ??
Old Mar 23, 2013 | 06:46 AM
RodiZio's Avatar
RodiZio
Building a higher compression turbo motor. I'm going to need cams to make it work. I'm also not sure what Im going to do with the crankshaft, not sure how much power and tourqe the stock one can take. This is my first import build, I usually build F/I mustangs. I have one now pushing 18lbs of boost that just made 700 on the dyno.
Old Mar 23, 2013 | 07:44 AM
0jiggy0's Avatar
0jiggy0
Sounds like you should research this forum a lil bit.
Old Mar 23, 2013 | 07:50 AM
padilla03z's Avatar
padilla03z
I call bs....if u built high horsepower cars u would know that high compression and boost equals pre-ignition unless ur tryin to run race fuel in there...sounds like ur just jabbing at a question to not get flamed for not searching
Old Mar 23, 2013 | 09:36 AM
RodiZio's Avatar
RodiZio
The motor has to be set up for it. I will set the cam and ignition time accordingly like I did with the mustang. Or maybe I should get some real low compression pistons and build a low budget turbo rat like the ones I see at the track every weekend.
Old Mar 23, 2013 | 10:34 AM
RodiZio's Avatar
RodiZio
I was interested in those cams because I can get them fairly cheap. However I just found specs on them and I don't think that they will offer enough valve lap during high rpm to benefit my high compression build.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
apex locator
Jul 23, 2021 02:27 AM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
