350z Transgo instructions
Old Mar 23, 2013 | 10:02 AM
Daytondakid13's Avatar
Daytondakid13
Default 350z Transgo instructions
Does anybody have a digital copy or can send one to me for 350z Transgo valve body upgrade thanks!
Old Mar 23, 2013 | 10:43 AM
DavesZ#3's Avatar
DavesZ#3
Wait, i thought you bought one here https://my350z.com/forum/10001068-post6.html and was getting it installed at a local shop. Didn't it come with instructions?
Read the DIY here https://my350z.com/forum/engine-driv...y-upgrade.html - you'd see in the first post that they can be downloaded from the GTM site.
Old Mar 23, 2013 | 10:06 PM
angel700's Avatar
angel700
Seeing that thread brought memories when i disassembled transmissions. Thanks
Old Mar 27, 2013 | 04:53 PM
Daytondakid13
Default installed transgo now its hard to put in gear
so i did the transgo mod and when i put my valve body back in the car the car is really hard to put in gear... i have not started the car or put new oil in it because i want to make sure it is correct first... so i pulled everything back out and tried to adjust the arm on the valve body a bit by loosening and retightening the bolts and broke 2 bolts that hold the arm on to the valve body assembly. so now... i will need 2 more bolts and still cannot figure out why it is hard to put in gear without the valve body in it is easy and smooth and the valve dboy arm moves easy as well but when i put them together its like something is causing it to bind up.
Justin100
Nov 29, 2015 03:58 PM
seagrasser
Oct 11, 2015 03:27 PM
TrboMike
North East
Sep 28, 2015 06:36 PM
