will i need a reflash
Old Jan 21, 2004 | 09:02 AM
milner's Avatar
milner
Default will i need a reflash
quick question. lets say the the following are installed:
injen ses straight tip.
high flow cat pipes.
injen cold air intake.
and finally a new plenium (not sure what brand to get )
now the question is who do i send the ecu to get flashed and why i am at it should i put some other little things on before i get it flashed such as : oil catch can, grounding kit , under drive pulleys, larger throttle body.
i just dont want to have to take it out and get it reflashed after i put some other stuff on.
thanks for any help....
Old Jan 21, 2004 | 01:18 PM
Chebosto's Avatar
Chebosto
if you are going to get larger throttle body, then i would suggest you wait for the flash until after you get that... that will definately alter the amount of air flow into the engine.. the other stuff like catch can and grounding kit will do nothing that would require a reflash..
the UDPs, eh. not really...
your cat back wont alter the airflow, but your cats and intake and plenum will.
send it to Technosquare for the reflash...
--Cheston
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
MIAPLAYA
Aug 30, 2004 09:53 PM
mlemieux137
Tuning
15
Aug 2, 2004 05:15 PM
zimbo
Jul 28, 2004 07:56 PM
chaknchngo
Apr 14, 2004 07:50 AM
