How much fuel pressure?
Old Jun 24, 2013 | 03:29 AM
RodiZio's Avatar
RodiZio
Default How much fuel pressure?
Anyone have an idea of what to set a adjustable fuel regulator at? I'm thinking its probably around 52 lbs.
Old Jun 25, 2013 | 03:49 PM
RodiZio's Avatar
RodiZio
Yep 52 lbs is correct
Old Jun 25, 2013 | 05:00 PM
binder's Avatar
binder
You can set it whatever you want. If you were previously tuned at 52psi then set it there. If you were not previously tuned then set it whatever you like. Remember it will drop under vacuum when you hook it up.
Old Jun 27, 2013 | 06:29 AM
RodiZio's Avatar
RodiZio
Yep just wanted a base number to start with, I'll set it where it needs to be on the dyno. Thx
Old Jun 27, 2013 | 10:12 AM
terrasmak's Avatar
Just a quick question, NA application, i don't want Vaccum hooked up. I have to run a FPR off my external pump for the surge tank.
Does pressure typically stay constant in stock form, will it remain constant with the Aeromotive FPR ?
Old Jun 27, 2013 | 11:05 AM
str8dum1's Avatar
str8dum1
it will stay constant fuel pressure up to the point your fuel pump canot flow enough to maintain the pressure.
Old Jul 11, 2013 | 02:01 AM
alexml's Avatar
alexml
and whats the OEM fuel pressure without any modification?
Old Jul 11, 2013 | 10:41 AM
amr_electron's Avatar
amr_electron
51 psi.
Old Jul 12, 2013 | 01:16 AM
alexml's Avatar
alexml
man i´m confused
PSI or lbs?????????
and what about kg/cm2??
do you realise that 52lbs is 23.5kg/cm2 and 51psi is 3.58 kg/cm2...
i think )
Old Jul 12, 2013 | 04:18 AM
amr_electron
man i´m confused
PSI or lbs?????????
i think )
From the FSM,
Old Jul 12, 2013 | 07:56 AM
QTB's Avatar
QTB
Pounds (lbs) is a measure of mass. Pounds per square inch (PSI) is a measure of pressure. Kilograms (Kg) is a measure of mass. Kilograms per square centimeter (Kg/cm^2) is a measure of pressure.
All to often people refer to pressure in lbs which is wrong, but we are a lazy people and say pounds instead of pounds per square inch.
Example:
Wrong way
Poser #1 "How much boost you runnin' yo?"
Poser #2 "30 pounds yo!"
Poser #1 "That's tight pimp yo"
Correct way
Guy #1 "How much pressure do your turbos produce?"
Guy #2 "Enough, now go away"
Guy #1 "Certainly"
Old Jul 12, 2013 | 08:47 AM
alexml's Avatar
alexml
OK...
now i know...
my bad...
thanks...
apex locator
Jul 23, 2021 02:27 AM
