07+ CSC Transmssion swap into DE 2003
Old Jul 29, 2013 | 08:34 AM
Blurvision's Avatar
Blurvision
Default 07+ CSC Transmssion swap into DE 2003
Well my 2003 transmission 3rd gear syncro is dead!
I have a lead on a 2008 transmission with the concentric slave cylinder style locally, for a really good price.
Is it worth to presue this swap?
I will need HR style clutch and flywheel? The CSC itself?
Any tips? Not much info I could find so far.
Old Jul 29, 2013 | 03:00 PM
HK350 Z's Avatar
HK350 Z
You will need an upgraded CSC and WillWood Master Cyl. Both can be had from Zspeed.
Old Jul 30, 2013 | 11:03 AM
Blurvision's Avatar
Blurvision
Ok, so the HR style clutch AND flywheel?
and the correct master and slave.
Old Jul 30, 2013 | 04:03 PM
Classy's Avatar
Classy
Before you get all giddy about this, I thought there were more differences than that, otherwise I would have had an HR transmission in my old Z
Old Jul 30, 2013 | 07:23 PM
djamps's Avatar
djamps
There's a thread on this somewhere regarding HR trans in a DE... aside from the bellhousing difference I don't think the input shaft is long enough (or short, can't remember). The guy ended up swapping the input shafts out and it was a *huge* PITA due to bearing sizes ect.
Old Jul 31, 2013 | 03:19 AM
Classy's Avatar
Classy
I am glad you knew more than me, I didn't want the OP to waste a bunch of money on this.
Old Jul 31, 2013 | 04:36 AM
ian99rt's Avatar
ian99rt
I believe the starters are on opposite sides as well. I know my HR starter is buried low on the driverside.
Old Jul 31, 2013 | 05:30 AM
djamps's Avatar
djamps
^^ Hence why I think the bellhousing needs to be swapped along with the input shaft.
Here's the pain involved:
https://my350z.com/forum/engine-and-...onversion.html
Old Jul 31, 2013 | 05:53 AM
Blurvision's Avatar
Blurvision
Ok, thanks for some good info there.
apex locator
Jul 23, 2021 02:27 AM
burglapfd
Dec 6, 2020 01:04 PM
