Horrible performance with new NGK Iridium plugs
Old Sep 8, 2013 | 04:24 PM
Bigsyke's Avatar
Bigsyke
Default Horrible performance with new NGK Iridium plugs
My 05 revup just hit 100k miles on it, so I decided to swap in Iridiums. I recently bought the car, and assume the plugs have never been changed. They weren't, and I've never seen spark plugs look that bad. I expected at least 100hp, as the gap was into the 0.70mm range. I installed the plugs correctly, didn't unplug anything but the coil packs. The torque increase in the low end was amazing.....for a few days.
Now, I'm almost thinking about swapping my 100k mile plugs back in, as all I have is rasp, a loud exhaust and a very noticeable power loss. Under no circumstances can I even get the tires to chirp, even when inflated at 45psi. Checked over the entire car, which is stock, (minus the exhaust), and found no issues.
Has anyone else had an experience like this?
Old Sep 8, 2013 | 04:27 PM
mr. sparco's Avatar
mr. sparco
Doubt it's just the spark plugs, probably a combo of maintenance related issues.
Old Sep 8, 2013 | 04:38 PM
2bad240's Avatar
2bad240
Stopped up cats?
Old Sep 8, 2013 | 05:24 PM
Bigsyke's Avatar
Bigsyke
Originally Posted by 2bad240
Stopped up cats?
I have Megan v2 test pipes. Only code I have is for rear 02 sensors
Old Sep 8, 2013 | 06:04 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Sounds like you dropped a cylinder
Old Sep 8, 2013 | 07:16 PM
WTFMike's Avatar
WTFMike
Is it misfiring? It is easy to mix up the plugs that go to the coil packs for the middle and rear cylinders on the drivers side.
Old Sep 8, 2013 | 08:49 PM
MonkeyMagic72's Avatar
MonkeyMagic72
So, did you check the correct gaping of the new plugs you replaced with 1.10mm from the old bad 0.70mm gap plugs?
Let's us see the pictures of those old plugs look like, so maybe we can tell what is wrong with your engine.
Old Sep 8, 2013 | 08:58 PM
DaveJackson's Avatar
DaveJackson
Master
You either messed up the install or your computer reset if you had the battery disconnected during the change and now it's re-learning in a way you don't like.
Old Nov 17, 2013 | 12:03 PM
crsracing19's Avatar
crsracing19
100hp off plugs?
Old Nov 17, 2013 | 12:48 PM
Spike100's Avatar
Spike100
Is your engine running smoothly?
I ask because the power loss you describe sounds as though you lost a cylinder (running on 5 now).
I have the same question crsrasing19 asks: "100hp off plugs?"
--Spike
Old Nov 17, 2013 | 12:49 PM
terrasmak's Avatar
What is the gap supposed to be at? Did you try and gap any of those plugs?
Old Nov 17, 2013 | 12:59 PM
SR71's Avatar
SR71
Lead Super Moderator
Originally Posted by crsracing19
100hp off plugs?
Damn, Im getting some new plugs.
Old Nov 17, 2013 | 01:00 PM
Spike100's Avatar
Spike100
I’ll bet you are on the right path here to discover the problem. He states that there is a problem with the oxygen sensors:
--Spike
Old Dec 2, 2013 | 10:17 AM
slvrman's Avatar
slvrman
im about to install some plugs and forget about motordyne parts haha
350z82
Oct 1, 2015 06:25 PM
35reilly
Sep 28, 2015 07:42 AM
