Clutch/Flywheel replacement, replace anything else?
Old Feb 10, 2014 | 10:32 PM
tphss's Avatar
tphss
Default Clutch/Flywheel replacement, replace anything else?
I just ordered a Mild performance Clutch/Flywheel combo kit from Z1 motorsports.
While I get the clutch/flywheel replaced and the car is on the lift, are there any things I should replace as preventive maintenance?
I do have the squeak from the throwout bearing, but the kit from Z1 says it comes with a Koyo throwout bearing already.
Thanks
Old Feb 11, 2014 | 01:56 AM
travlee's Avatar
travlee
Master
Thanks
maybe the roller bearing, and pivot ball
Old Feb 11, 2014 | 02:30 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Replace everything. Get SS clutch line. New fluid etc
Old Feb 11, 2014 | 04:57 PM
Toneloc's Avatar
Toneloc
pivot ball, ss clutch line and do the master slave while your in there... I had mine done acouple months ago
Old Feb 11, 2014 | 05:12 PM
tphss's Avatar
tphss
Thank you, should I get a stock replacement pivot ball?
Mine is a 2003 and I see it's different from later models. The Z1 pivot ball is about 4 times more expensive than the OEM one.
And for a clutch slave should I just get an OEM one? It's around $60
This replacement looks good for $25:
Amazon.com: Dorman CS650096 Clutch Slave Cylinder: Automotive Amazon.com: Dorman CS650096 Clutch Slave Cylinder: Automotive
What do you think?
Old Feb 12, 2014 | 01:54 AM
travlee's Avatar
travlee
Master
What do you think?
think you need to look other places, rockauto.com has the same slave for $16.30
Old Feb 12, 2014 | 12:28 PM
RENFRO's Avatar
RENFRO
What do you think?
'03? Get a CD009 Transmission. That's what I did when I swapped in the Z1 Mild Clutch & Flywheel. One of the best upgrades if you have the $$. Also might want to consider doing headers while the transmission is out of the way.
Old Feb 12, 2014 | 01:31 PM
tphss's Avatar
tphss
Too much $$$ for this... And my transmission feels great.
I just got my Z a little while ago and I already ordered over $3k in parts that I didn't install yet (LSD, sway bars, Koyo rad, Z1 clutch/flywheel and much more).
Old Feb 12, 2014 | 05:00 PM
Toneloc's Avatar
Toneloc
What do you think?
I got all my stuff from conceptzperformance...they have the best deals and cheaper shipping then z1...yes get the upgraded one...I did my slave because the stock one was sticking plus I don't have to worry
Rev_Night
Nov 7, 2020 06:00 PM
350z82
Oct 1, 2015 06:25 PM
pr_350z
Oct 1, 2015 05:03 PM
