Installing tomei 280 duration cams help
Old Oct 14, 2015 | 07:59 PM
mexicutioner350's Avatar
mexicutioner350
Default Installing tomei 280 duration cams help
Good afternoon fellow z gear heads. The time has come to strap the heads to the block but my issue is the timing. I have read the directions over and over again. But for some reason the directions are making it harder than what they make it out to be. is there anyone that could guide me to a possible link for timing on these vq motors?
Sincerely Jose
also i have looked high and low for insulation write up but came up empty handed .
Old Oct 17, 2015 | 10:28 AM
thekyledeg's Avatar
thekyledeg
look in the DIY i have a thread in there on how to do cams.
Once you have the cams and caps in: grab the intake and exhust gears, place the chains timing marks in the correct position and have a friend rotate the cams so they are indexed correctly so you can slide both gear assemblies on at the same time.
Once you have the in/ex cam gears and chain on; and those tensioners released you can then lay the main timing chain. Put a pin in the main tensioner to relieve the tension. Align all the timing marks between the crank and cam intake gears; then go ahead and let the tensioner out and your done.
Old Oct 24, 2015 | 07:21 PM
mexicutioner350
Default Link to thread
I looked in the diy but found multiple threads do you mind posting the link? I will look again just got back on my350z work has been keeping me busy.
Old Oct 25, 2015 | 10:32 AM
thekyledeg's Avatar
thekyledeg
https://my350z.com/forum/engine-driv...e-springs.html
there ya go. Anny questions feel free to PM me
Wu-Watt
Engine Swaps
31
Oct 14, 2019 11:41 AM
thekyledeg
Nov 4, 2015 08:32 AM
ssmokeyy
Oct 17, 2015 07:30 AM
bradkculp
Oct 14, 2015 06:46 PM
norris_83
Oct 13, 2015 05:28 PM
