Alright I need some help with my clutch..
I just purchased my 2007 350z nismo from a guy who claimed to have changed the flywheel and clutch and it ran fine for 8 months..
Now, the fluid fior the clutch is going somewhere, can't find where.. the clutch pedal loses pressure and within about 10 - 15 minutes it loses pressure completely, is this the mster or slave?
I did the slave all went great.. but it seems as though it hid another problem
Now, the transmission 1st to 2nd grinds going in to second unless i rev match perfectly, even with clutch in..
I assume synchro issue?
During my "test drive" couldn't exactly shift properly due to the clutch going to the floor so had no way of knowing.
Understood and thank you for moving the thread, I see where I messed up
Hi guys, I am in a similar situation where my 08 Zs clutch bottom out when I try to launch the car. It wouldn't shift in any gear until the clutch pops back up.
So I am assuming its also my master slave cylinder. I have looked at the master slave cylinder delete or the upgrade to a heavy duty master slave cylinder. Which one would be better? I will also be upgrading to JWT clutch and lightweight flywheel while getting this master slave cylinder problem fixed. Can someone please help?
Should I get this:
http://www.zspeedperformance.com/ZSp...03-ZSP2006.htm
OR this:
https://www.z1motorsports.com/z1-pro...it-p-7340.html
I'm pretty confused.
Should I get this:
OR this:
Should I get this:
OR this:
Should I get this:
OR this:
Apr 2, 2016 01:23 PM
