Differential Setup
Old Apr 23, 2016 | 10:26 AM
Tomek350Z's Avatar
Tomek350Z
Default Differential Setup
Thinking about buying a seperate setup for me base 07 (open diff) Z. Wanting to get 3.9 gears and a Quaife helical diff. How many people have actually setup up their own differential on here. Looking through service info, there are special tools (J-34309) that are need to setting proper pinion depth shim. I tried looking for the kit but it doesn't seem to come up. Anyone had luck with universal kits? The only way to really get around this is by keeping the factory gearing so that I do not have to mess with the proper depth shims/ pinion variance. But even so, swapping out differentials may need adjustment on the side bearing shims for pre-load. Any advice would be beneficial.
Old Apr 23, 2016 | 03:11 PM
HRMoneyPit's Avatar
HRMoneyPit
My paying Z1 to do mine then they will ship it back cause I dont trust myself and they gave a good deal
Old Apr 23, 2016 | 09:12 PM
dcains's Avatar
dcains
Unless you plan on changing diff's often, just take it to a shop and have them set it up. If you bring them the pumpkin and the parts, it won't be too expensive and it will be done correctly.
frankiie_Z
Apr 21, 2016 12:33 PM
2one8
Apr 12, 2016 05:14 AM
NeVrO
Mar 20, 2016 10:25 AM
STEVE 6483G
Aug 18, 2003 04:57 PM
ICYBLUE1203
Feb 23, 2003 12:51 PM
