2006 Nissan 350z Swapped with a 2004 Engine
Old Jun 9, 2016 | 10:43 AM
oggy's Avatar
oggy
Default 2006 Nissan 350z Swapped with a 2004 Engine
Hey guys,
I purchased a 2006 nissan 350z with a blown engine because I have fine 2004 VQ35de engine in my storage unit with only 50k miles that I plan on putting into the 350z.
The 2006 350z is the Enthusiast model and also it also has a vq but its the rev up model.
I was wondering if there are any major issues that will pop up during this swap.
I do have the vq35de(2004) engine with its ecu and wiring harness, but as far as that goes will I still be able to "plug" in the engine without having any issues with the driveshaft, mounts, or anything?
Old Jun 9, 2016 | 10:44 AM
turboed350z's Avatar
turboed350z
Im 99% sure its a straight plug and play assuming you change the ecu and blah blah blah.
Old Jun 9, 2016 | 11:13 AM
oggy's Avatar
oggy
I figured i was just curious, thanks
Old Jun 9, 2016 | 12:03 PM
CK_32's Avatar
CK_32
Yea I think a thread a couple months ago said, motor, ECU and harness is all that's needed to swap.
Old Jun 9, 2016 | 12:21 PM
turboed350z
Yup all the electronics. But he was more concern with the mechanical parts i believe
Old Jun 9, 2016 | 01:20 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Where you from in Mass? Did you buy the black car from New York that was on craigslist for like a day?
Old Jun 9, 2016 | 05:02 PM
venture210's Avatar
venture210
Don't forget about marrying the ECM, IPDM,BCM and key together. That or disable the NATS with uprev
Old Jun 9, 2016 | 07:18 PM
oggy's Avatar
oggy
No I got a red one from CT with straight pipes from cats back.
Old Jun 9, 2016 | 08:46 PM
terrasmak's Avatar
Obviously the second set of cams will not have the sensors plugged in. I bet you can turn those featured off with uprev and tune it as a normal DE. It's a chance, if not you would need to swap to a 04.5 or 05 ECU and harness
jdmfetish
Interior
19
Apr 18, 2016 05:48 AM
Grievous3
Apr 1, 2016 05:24 AM
Stephen_Neri
Mar 23, 2016 09:33 AM
