Engine swap?🤔
Old Jul 20, 2016 | 12:49 PM
Jordyy_z33's Avatar
Jordyy_z33
Default Engine swap?🤔
So I blew my DE engine on Saturday 😭😭..instead of getting a DE engine I'm thinking of swapping to HR. Besides changing the manifold what else would I have to change and is their any recommended mechanic in the IE area?
Old Jul 20, 2016 | 01:00 PM
CK_32's Avatar
CK_32
Im pretty sure Ive read all that's needed is ECU and harness.
But many guys also follow that up with the HR isn't worth it as far as getting "better" performance for the cost. Its not THAT much better of an engine (Their words not mine).
And usually recommend just staying DE or finding a MUCH better engine for a little more if possible.
Old Jul 20, 2016 | 01:10 PM
Jordyy_z33's Avatar
Jordyy_z33
I thought going HR will give more more since that engine is stronger, holds longer gears and saves oil lol! I found a HR engine for the same price as a DE, so that's why I'm asking. So getting a HR I don't have to change the manifold? Just harness and ecu?
Old Jul 20, 2016 | 01:26 PM
CK_32's Avatar
CK_32
I don't know I have not personally done it. But just passing on what other have said in the threads of past.
So hopefully one of the other guys can answer that for you.
Old Jul 20, 2016 | 02:07 PM
travlee's Avatar
travlee
Master
Its a very tight fit, not to mention you need the newer hood, preferably the cd009 trans to go with engine
How did you blow yours?
Old Jul 20, 2016 | 02:19 PM
Jordyy_z33's Avatar
Jordyy_z33
Danm I guess I'll get a job DE instead cause I don't want to spend money on a new tranny...
I had full bolt ons on a old engine..
Old Jul 20, 2016 | 02:26 PM
travlee's Avatar
travlee
Master
Not to mention, i think the de trans wont bolt to hr motor.
Old Jul 20, 2016 | 02:28 PM
travlee's Avatar
travlee
Master
Btw, bolts ons didnt blow the engine.....did you run it low on oil, beat the shiite out of it, what.
Old Jul 20, 2016 | 02:36 PM
Jordyy_z33's Avatar
Jordyy_z33
nope I had just installed my headers and then it blew like a week later...I always did my oil change every 3k mile
Old Jul 20, 2016 | 02:40 PM
travlee's Avatar
travlee
Master
You do know if you did headers, you really needed to have it tuned
Not to mention they arent worth the minimal gains for the pita install
Old Jul 20, 2016 | 03:17 PM
Jordyy_z33's Avatar
Jordyy_z33
i know I was going to get it tuned but I didn't think it would go out on me.
And headers give a pretty nice gain,well at least I think so
Old Jul 20, 2016 | 03:19 PM
travlee's Avatar
travlee
Master
google "what happens if you run your engine lean", you will see what prob happened. best of luck to ya, and note.....after new motor, get it tuned
Old Jul 20, 2016 | 04:02 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Having completed an HR swap for a racecar in the past, let's just say you've been reading the wrong threads. There are a ton of parts that need to be swapped over and it would be helpful to have the entire front clip to do the swap.
The OP is making a wise decision to go with a rebuilt DE engine...
Old Jul 20, 2016 | 04:04 PM
travlee's Avatar
travlee
Master
aaaahhh, i was trying to remember who did it..... i was thinking you or dcains....knew it started with a D
Old Jul 22, 2016 | 05:16 PM
TT03Z's Avatar
TT03Z
If u wanted to swap the car I would personally go with an LSX or LQ9. Probably around the same price but more work/wiring/parts. But the power gains would out way the cost. Just my $.02.
Old Jul 23, 2016 | 01:06 AM
openupitsdave's Avatar
openupitsdave
Whats your guys' opinion on 2jz swap? Will the stock turbos and piping fit in the 350z bay?
2jz is alot cheaper than the LSx....but will stock 2jz be a significant increase over the vq?
Old Jul 23, 2016 | 01:22 AM
finewayne's Avatar
finewayne
There is no arguing the potency of the 2JZ-GTE motor. It's power potential is extreme and aftermarket support is strong, these are could be reference for swaps 2jz
http://www.superstreetonline.com/fea...ite-2jz-swaps/
Old Jul 23, 2016 | 07:10 AM
ZMoneyPIT's Avatar
ZMoneyPIT
Dreamer thread. Swaps cost money. Don't have 10k+ to play with? Forget about it.
Old Jul 24, 2016 | 06:29 PM
mignav01's Avatar
mignav01
You were asking questions on how to swap in an HR, and while that's no simple task, the 2jz surpasses that in time/money/fabricating. Not to mention that while it's an amazing motor, in Stock form it's not that awesome. It's known for its potential to withstand way too much boost for mere mortals
quickdiversion
Oct 1, 2024 05:31 PM
350zenth
Jul 29, 2016 02:00 PM
spartikus1975
Jul 25, 2016 07:15 AM
sbaik610
Jul 25, 2016 06:47 AM
user 68320
Jul 15, 2016 07:55 PM
