350z low clutch engagement point after engine replacement
Old Jul 19, 2016 | 06:11 PM
350zenth's Avatar
350zenth
Default 350z low clutch engagement point after engine replacement
what's up im new here. bear with me because I may not put everything on here that you guy's need to know. but today I just got my car(04 350z 6 speed) back from my mechanic who replaced the engine. while the engine was out in decided to replace the clutch because I didn't know how old it was. so when I picked up the car I stalled so many times because the clutch started grabbing at the most one inch from the floor and I told him why it was like that and he said because it's a new clutch(let it break in). he also said he didn't mess. with any of the transmission solenoid something. i don't know what he even said but is that normal for the clutch to be like that. sorry guy's I don't know much about cars. thanks in advance
Old Jul 19, 2016 | 06:24 PM
dcains's Avatar
dcains
This may be something as simple as the adjustment rod on the clutch master cylinder. The spec is in the factory service manual. Since you mentioned you're inexperienced, you may want to have a Nissan factory mechanic check that adjustment for you, but it's actually quite simple. Also, the Z is known for having a clutch with a horrible feel and poor modulation of the engagement point, so part of it might be that. RJM makes an adjustable clutch pedal pivot kit, and it's one of my favorite upgrades on my Z.
Old Jul 19, 2016 | 06:39 PM
350zenth's Avatar
350zenth
the clutch point before was somewhere between a quarter to the halfway point and now it is very low though. would a clutch really cause that to happen. thanks for your input
Old Jul 19, 2016 | 06:43 PM
dcains's Avatar
dcains
Yes, but I think it's an adjustment, and not just because the clutch is new. Usually, from the factory, the clutch would engage with the pedal high, not near the floor.
Old Jul 19, 2016 | 06:46 PM
350zenth's Avatar
350zenth
alright thanks. I also forgot to mention that I have my foot pushing down the clutch hard and even then I sort of have to put quite a bit of effort to get it into gear. I've heard it could be air in the clutch lines but I'm not sure
Old Jul 19, 2016 | 06:49 PM
dcains's Avatar
dcains
Well, that's actually very important information. In that case, the first thing I'd check is that the hydraulics are properly bled. Could also be a failing slave or master cylinder, but have the bleed done first.
Old Jul 19, 2016 | 07:01 PM
350zenth's Avatar
350zenth
ok. I just called him and he said he didn't open the "system" so it didn't need to be bled but he can bleed it for me to try to fix the problem. would it really be the clutch master cylinder because I've never never had any clutch problems before?
Old Jul 19, 2016 | 07:18 PM
dcains's Avatar
dcains
Hydraulic parts wear out, and it could be the master or slave. The bleed will tell, because if the system can't be bled, that indicates a worn master or slave. It's best to replace both at the same time, and then you'll be good for a long time, but, bleed first, and see what happens.
Old Jul 29, 2016 | 02:00 PM
vegasanthony's Avatar
vegasanthony
I would buy one asap...if you read the RJM thread he is on version 4 and making only one more batch.
OP..imho any decent mechanic should be able to trouble shoot that clutch specially If he/they put the engine in..any chance you were driving it before the bad engine..was it like that before?
Lithg
Jun 23, 2016 06:48 PM
MichaelaZ
May 6, 2016 10:18 AM
cincysilvias14
Apr 7, 2016 07:13 AM
Grievous3
Apr 1, 2016 05:24 AM
TCL
Jun 7, 2002 03:01 PM
