CD009 years?
Old Oct 26, 2016 | 06:22 PM
tarek gabris's Avatar
tarek gabris
Default CD009 years?
I have researched all over the internet and I can't find solid information on what models came with CD009. Some say 2005 some say 2006 with the rev-up. Can someone once and for all tell me the correct answer?
Old Oct 26, 2016 | 07:28 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Hope this helps:
https://my350z.com/forum/engine-and-...l#post10700084
And later in the same thread....
https://my350z.com/forum/engine-and-...l#post10700618
Essentially 2005-06 for DE, '07-08 use the JK4x trans. But be careful, not ALL '05s came with the 009, you have to look carefully at the case markings.
Old Oct 26, 2016 | 07:47 PM
tarek gabris
Originally Posted by MicVelo
Hope this helps:
Essentially 2005-06 for DE, '07-08 for HR. But be careful, not ALL '05s came with the 009, you have to look carefully at the case markings.
finally, thank you. the problem is i'm looking for one online and i can't really tell if it does have it, so i'm just sticking to anniversary edition/track 05+.
Old Oct 26, 2016 | 08:02 PM
MicVelo's Avatar
Ooooooohhhhhhhhhhhhh... you're looking for a whole car WITH CD009...... get it now. Thought you were looking for just a tranny. Well, here's a tip....and it's arguable by many but if you're looking for a Z, the "more desirable" ones are the '07-08 HR (with JK4x trans, by extension) cars.
I'm neutral, having owned both DE/HR as well as VQ37VHR so not recommending one over other just pointing this out due to the slightly higher power rating and slightly freer to rev character of the HR and VHR due to internal changes (cams and otherwise).
Good luck hunting.
Old Oct 26, 2016 | 08:52 PM
tarek gabris
Ooooooohhhhhhhhhhhhh... you're looking for a whole car WITH CD009...... get it now. Thought you were looking for just a tranny. Well, here's a tip....and it's arguable by many but if you're looking for a Z, the "more desirable" ones are the '07-08 HR (with CD009, by extension) cars.
Good luck hunting.
i'm neutral as well, i'm just looking for the best deal. no major mods (maybe cams if i get DE so i can be in the 300whp mark) but other than that just bolt ons, kw v3 (still debating on what to get in terms of coilovers) and quiafe diff because it's good for both daily and track.
Old Apr 7, 2022 | 11:32 AM
GwiththeZ's Avatar
GwiththeZ
Default First time forum user
I’m currently on a mission to start my first engine swap into a 76 Datsun 280z & want to choose the vq platform out of popularity & the availability of mounting hardware/parts/etc. I have heard so many conflicting opinions on which is better/worth the price & I wanna hear it from someone who knows all them even if it’s behind a screen. I know that I want the cd009 trans but can’t decide if the HR is worth it or not. Please help
-Graham
Good luck hunting.
Old Apr 7, 2022 | 02:26 PM
MicVelo's Avatar
-Graham
There is more aftermarket support for the DE and less routing issues for the HR airboxes and such; BUT the S30 has more than enough room to take a PAIR of fabricated inlet pipes so no real issue. But cost is another thing. The DE was available for four years (plus the RevUp version) and you might be able to find a DE easier and cheaper than an HR. Consider as well that the HR engine does NOT accept the CD009 transmission. HR engine use the JK4x trans which is internally the same as the CD009 BUT does not bolt up to the DE block so you'd need to source a complete HR engine/JK trans (or find them separately and mate 'em).
Make sure that whatever donor you get comes complete with the entire engine wiring assembly (or purchase/fab a new one) including the black box (ECM) unless you're going to convert it all to a standalone ECU. Without having it all, the swap goes from mundane to nightmare. The 280Z - since it already has injection - has the return lines you'll need for fuel but not sure the OE undercar e-fuel pump is adequate for the VQ - might have to look into upgrading that to a proper pump.
There IS an easier (same amount of work electronics wise but fit is easier given the inline-6 configuration) - albeit more costly - swap that keeps with the spirit of the Gen 1 Z.... RB25DET mated to a CD009 transmission using an adapter.
Or, if you wanna break the bank and still keep the S30 spirit alive. Datsunworks KN20 24v head on built L28 block with Jenvey ITB induction. The spirit of the 432Z lives!
OK, not trying to talk you out of a VQ swap as it's solid. But my choices for next S30 build are obvious. Laff.....
alanshs
Nov 29, 2020 09:18 AM
Vinnybiz
Aug 28, 2019 12:11 PM
achelon3198
Feb 20, 2013 06:07 PM
Shin Beats
May 18, 2010 06:27 AM
kgkeen101
Jan 29, 2010 10:53 AM
