got my first dyno today!!
Old Feb 16, 2004 | 08:01 PM
pricanz's Avatar
pricanz
Question got my first dyno today!!
hello everyone
just wondering about what you think about this numbers because i havent got a clue if they are any good:
the car is stock with injen CAI they did it without the big fan and they only did 2 pulls
1st 236 hp & 2nd 231 hp I cant remember the torque right now but ill post the torque tomorrow. the price was $50.00 for the 2 pulls
Is this expensive?
input will be apreciated
Jose
ps I reced a mustang comming home, I smoked him 3 separate times on the highway side by side on 4th gear I was surprised!
Old Feb 16, 2004 | 08:04 PM
Philthy's Avatar
Philthy
Boost Junkie
Big fan is very important.. Make sure they use it next time...
Old Feb 17, 2004 | 01:23 PM
jjellyneck's Avatar
jjellyneck
Default Re: got my first dyno today!!
Originally posted by pricanz
hello everyone
Is this expensive?
Jose
I'm interested in seeing the dyno chart WITH the A/F ratios included. I'll look for your post!
Old Feb 17, 2004 | 04:55 PM
pricanz's Avatar
pricanz
Default Re: Re: got my first dyno today!!
sorry for the dumba** question but what is A/F?
the torque is 226 on both runs
Old Feb 17, 2004 | 05:02 PM
iLLestJrz's Avatar
iLLestJrz
Air Fuel Ratio can be measured by the graph in the Dyno plot. It will tell you if your Z is running lean or rich. One way it can be adjusted by aftermarket ECU's, or Apexi Super AFC. Ideal A/F is around 12.5.
Old Feb 17, 2004 | 05:21 PM
ares's Avatar
ares
Veteran
auto or manual?
mustangs are easy kills above 70mph, they end up in 5th gear and die.
Old Feb 17, 2004 | 05:42 PM
PhoenixINX's Avatar
PhoenixINX
Your numbers are not reflecting what your car can pull...
For a car to reflect "Racing" conditions your oil HAS to be up to temperature.
Two pulls has just begun to warm everything up.
Keep making pulls until your fans cut on, once they do... let them run... once they shut off, that next pull 99% of the time will be nearly your highest.
Seriously, two isn't going to cut it.
Old Feb 17, 2004 | 05:55 PM
JawKnee's Avatar
JawKnee
Assuming the first 2 aren't "identical", you would need at least another pull to validate one of the first 2 runs.
Old Feb 18, 2004 | 04:31 PM
pricanz's Avatar
pricanz
thanks for the input guys
they charged me 50 bucks for two pulls
is that reasonable?
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Rev_Night
Nov 7, 2020 06:00 PM
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
