Clutch fork not aligned with slave cylinder
Old Apr 8, 2018 | 01:40 PM
WizzRobe's Avatar
WizzRobe
Default Clutch fork not aligned with slave cylinder
Hello all, any idea why my clutch fork isn’t aligned with my slave cylinder? Should the slave be replaced or is it possible the fork is jammed somehow?
I replaced my clutch last weekend and cleaned inside the trans, the throw out bearing, and replaced the pivot ball. Is it possible I screwed up the way the fork aligns with the slave when reattaching it to the ball?
Images below.
Also if this helps, I noticed some issues with my clutch pedal sticking once I put everything back together. I flushed fluids, bled my lines, done just about everything but replace the slave. I am waiting for my slave replacement in the mail and am running a Wilwood master cylinder so wasn’t really expecting my pedal to start sticking.
Old Apr 8, 2018 | 03:05 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
its like it is only hooked on one side of the bearing sleeve
Old Apr 9, 2018 | 05:43 AM
Atreyu'z 350's Avatar
Atreyu'z 350
Images below.
If it didn't look like this prior to you doing all of that, then yes, it is possible that you screwed up the reassembly.. Take it apart, inspect, correct, then reassemble. Page CL-13.
http://www.nicoclub.com/FSM/350Z/coupe/2005/cl.pdf
Old Apr 9, 2018 | 12:02 PM
iideadeyeii's Avatar
iideadeyeii
I feel like if you take the slave off you can finagle the fork into the bearing
Old Apr 19, 2018 | 09:54 AM
WizzRobe's Avatar
WizzRobe
I am getting ready to try this weekend. Thanks for the valuable info and the link.
Is there any explanation as to why the clutch pedal is nice and stiff and comes right back up when the car is off but sticks down when it’s on? If the physical position of the fork was causing it to stick, wouldn’t it stick when the car was off as well?
sherm
Apr 11, 2020 05:21 PM
adamgfn
Drivetrain
Sep 25, 2015 10:52 AM
Slexis200
Jun 24, 2003 04:04 PM
