Reliable road racing DE
Old Jul 7, 2018 | 04:18 PM
Thefbomb13's Avatar
Thefbomb13
Default Reliable road racing DE
Want to build a reliable DE motor for my club racing z that I can beat on, and looking for opinions!
I know I can get a rev up or hr but it would probably be around the same price for the conversion, but I have multiple DEs lying around.
Was looking at Z1 motorsports kit, seems it may be a little cheaper all bundled up.
https://www.z1motorsports.com/engine...el-p-4265.html
Thanks!
Old Jul 7, 2018 | 06:20 PM
bealljk's Avatar
bealljk
a DE to Rev-Up/HR swap wouldnt be worth it unless you have some serious funds...
Just get a do a DE and modify as most you can within the letter of the law of your spec class
Old Jul 8, 2018 | 05:24 AM
dnash's Avatar
dnash
Looks like a good start. I would look into options for upgrading the oil pump. Depending on power/rpm goals, the revup pump would probably work well.
Old Jul 8, 2018 | 03:52 PM
Thefbomb13's Avatar
Thefbomb13
Yeah exactly what I was thinking
Compared to Nismo?
also, not sure what I should do with the valve train!
Old Jul 8, 2018 | 07:02 PM
JTeeAre's Avatar
JTeeAre
Compared to Nismo?
Well the revup pump was designed to support the redline increase in the revup engines over the regular DE redline. HOWEVER since you want it as a race car I think there will be a good chance you will raise the redline as you upgrade the engine. According to Z1 the Nismo oil pump is good for 8500 rpm. With that info I think you're the only one that can make the choice as to which will suit you best as only you know if you will raise the redline in the future or not.
Old Jul 8, 2018 | 09:30 PM
bealljk's Avatar
bealljk
Compared to Nismo?
consider this variant -
http://www.suckerpunchmotorsports.co...-vq35de-03-06/
Old Jul 9, 2018 | 06:13 PM
guitman32's Avatar
guitman32
Stock DE motor + Cooling Mods =
Old Jul 23, 2018 | 08:48 AM
Desert Z's Avatar
Desert Z
I am in the same boat. I am just going to keep my rev up motor and just get an oil cooler and focus on suspension/brakes.
Old Jul 23, 2018 | 09:28 AM
iideadeyeii's Avatar
iideadeyeii
If you're not going FI just use a stock motor?
Old Jul 24, 2018 | 07:22 AM
Cracka350's Avatar
Cracka350
BTW if you haven't already look into suspension options if you're looking to race. Suspension is king.
Old Jul 26, 2018 | 04:18 PM
rcdash's Avatar
rcdash
You can put a rev up oil pump on a DE. The variable exhaust valve timing on the revup adds very little power. It's not worth the change to the different pistons that allow for more blowby in the revups. Get an oil cooler on there and monitor temps. Sway bars, racing pads, tires and good to go!
Old Aug 31, 2018 | 10:19 AM
Cracka350's Avatar
Cracka350
I've found this vid to be extremely useful.
Old Aug 31, 2018 | 12:38 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Also would suggest a set of powdercoated HR headers. They are a bolt-up piece and better at scavaging exhaust.
jdm mike
South East
Apr 26, 2011 10:59 AM
andre12031948
Dec 4, 2010 08:05 PM
ZULATOR
Jul 26, 2003 06:17 PM
