limp mode now start problem.
Old Nov 24, 2018 | 02:21 PM
Sean Wilson's Avatar
Sean Wilson
Default limp mode now start problem.
SOLVED: Crankshaft Sensor came lose. Probably didn't torque it enough after replacing my clutch.
seems to struggle to keep 500rpm. I tried giving it gas with no response.
On the way home the car seemed to go into some kind of limp mode. any time I'd go past 2,500 Rpm in any gear the car Would bog horribly. Started happening on the highway 10 minutes from my house. I tried to start the car later and today and this it what would happen.
The fuel pump still primes. Surely this isn't the MAF? It's just not starting properly. Maybe throttle body?
It's been raining these last few days, but the car has been covered the whole time.
Car has 80k miles, year 2006, and no mods.
Old Nov 24, 2018 | 02:31 PM
travlee's Avatar
travlee
Master
How many miles, year, mods. My guess would be Replace cam shaft sensors witg oem
Old Nov 24, 2018 | 02:33 PM
Sean Wilson
Added car details
Old Nov 24, 2018 | 02:56 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Try pulling codes before you do anything else.
Old Nov 24, 2018 | 03:02 PM
Sean Wilson
Originally Posted by dkmura
Try pull codes before you do anything else.
Will be able to when my wife comes home with my scanner. Definitely waiting.
Old Nov 24, 2018 | 10:13 PM
Sean Wilson
p0335 pending code. Guess i'm replacing camshaft sensors
Old Nov 25, 2018 | 02:44 AM
travlee's Avatar
travlee
Master
Use oem
Old Nov 25, 2018 | 06:11 AM
karlt's Avatar
karlt
P0335 is a crankshaft position sensor code, not a camshaft sensor code.
Old Dec 1, 2018 | 06:50 PM
Sean Wilson
I replaced the passenger crankshaft position sensor and reset ecu with no change.
Old Dec 2, 2018 | 02:52 AM
karlt's Avatar
karlt
There is only 1 crankshaft position sensor and it's mounted on the upper oil pan next to the flywheel. You may have replaced the wrong sensor.
Old Dec 2, 2018 | 05:21 AM
travlee's Avatar
travlee
Master
And he prob used aftermarket sensors which more times than not dont work right
Old Dec 2, 2018 | 10:11 AM
Sean Wilson
Solved! Thank you.
Totally replaced the camshaft sensor instead of my crankshaft sensor.... Turns out my Crankshaft position sensor had come lose somehow. I just had to tighten the bolt back up. I Had recently done my clutch with help from a friend. Seems like we didn't torque it enough.
Car works fine now.
johnmlebel
Jul 11, 2016 03:35 PM
Moncef
Tuning
Jun 9, 2016 03:43 AM
Blwn_By_Twins
Jun 18, 2008 11:39 AM
Axelerate
Feb 14, 2008 05:46 AM
jining
Feb 2, 2008 10:10 AM
