2006 350Z Engine knocking?
Old Jul 17, 2019 | 02:51 PM
BostonianBoss's Avatar
BostonianBoss
Default 2006 350Z Engine knocking?
Hey everyone,
thank you you for taking a minute to helping me out. My 350Z just started making this (seems) knocking sound, but it doesn’t fully sound like it. Here is a YouTube video. Any advice would be greatly appreciated. Thanks!!!
Old Jul 17, 2019 | 03:07 PM
bealljk's Avatar
bealljk
sounds like you have a spun bearing...
heres my thread - check out post 655 and after for my symptoms and remedy.
https://my350z.com/forum/forced-indu...-build-14.html
Your best bet will be to stop running the engine and get it rebuilt. The more you run the engine the more damage you'll inflict.
Drain your oil and look for the gold flakes of bearing material.
If you are looking for a replacement OEM main, rod, and thrust bearing set I have a the ACL OEM oil clearance set I'll sell you for super inexpensive as I bought them and then went with the same set with more oil clearance and I can't return the OEM oil clearance set.
Old Jul 17, 2019 | 03:08 PM
BostonianBoss
On a scale of 1-10 on how bad that is???
Old Jul 17, 2019 | 03:18 PM
bealljk's Avatar
bealljk
probably a 7 or 8 on the **** hitting the fan scale...Its not the end of the world but you need to stop running the car or you'll destroy more and more components and rebuild the block.
or, find a donor block to drop it in and salvage out your hurt block.
Old Jul 17, 2019 | 03:19 PM
BostonianBoss
No longer running. Just started yesterday and parked immediately. You’ve got to be kidding me.......arrrgggg
Old Jul 17, 2019 | 04:15 PM
BostonianBoss
How much are you willing to sell the ACL for?
Old Jul 17, 2019 | 05:24 PM
bealljk's Avatar
bealljk
Z1 sells the main, rod, and thrust bearings for $216. How about $100 for the bearing set and cover the first $10 of shipping?
https://www.z1motorsports.com/engine...gs-p-3985.html
to please the mods:
Old Jul 17, 2019 | 05:26 PM
BostonianBoss
Do you have the main and Rod?
Old Jul 17, 2019 | 05:39 PM
bealljk's Avatar
bealljk
All three sets - you would want to change out all three sets if you’re going to do it
Old Jul 17, 2019 | 05:40 PM
BostonianBoss
I assume it would be best? Your thoughts?
Old Jul 17, 2019 | 05:59 PM
bealljk's Avatar
bealljk
My thoughts are do your due-dilligence. I see a classic case of a worn/spun bearing but I am 3000miles away. I would suggest you do this:
A. drain the oil and see if you see gold specs/flakes (indicating worn/blown bearings).
B. hire/bribe/ask nicely if a buddy and/or seasoned mechanic will come look at the car. If you start the car up for 5 seconds to have a mechanic look at it, it's probably ok
C. consider all your options - do you rebuild your block or do you source a donor?
D. Make a plan with respect to the above.
If you decide you want to rebuild your block and you determine you need new bearings and would like to buy these at 1/2 price than make it happen. I'm rebuilding an NA block at some point in time and if these dont get sold than theyll go into my NA block.
Old Jul 17, 2019 | 06:03 PM
BostonianBoss
Ok, I’ll buy it.
Old Jul 18, 2019 | 07:19 AM
Desert Z's Avatar
Desert Z
OP, we're both from Palm Springs. What do you drive? I might have seen you around!
At this stage my guess would be to get a second opinion on this. There are mobile mechanics. It would be well worth your money!
Old Jul 19, 2019 | 05:53 AM
Cracka350's Avatar
Cracka350
I've spent alot of time in the LKQ junk yards in MD lately. Motors in general are about 400 dollars. Weigh your options. Either way you have to take off the front end. Do you want to go through the pain and scary technical precision of rebuilding your motor, or would you like to drop in someones mileage? Best of luck!
Old Jul 19, 2019 | 07:22 AM
bealljk's Avatar
bealljk
I agree with pretty much 100% of this and if you a relatively new to the car game and don't have the experience than pay someone to give you a unbiased opinion of your situation.
Both have their ups & downs -
Rebuild -
Pros -
you'll have the opportunity to replace components that need replacing for the longevity of the car
you'll have a motor that will run for 200k miles plus.
You know the history from start to finish and will have documentation of the process
Cons -
will be more expensive than a junk-yard motor swap
the car will be down for a week or so while the block is being repaired/rebuilt
Donor Engine Swap -
Pros -
will likely be less expensive
will likely take less time
Cons -
it's a gamble as the donor engine may have age / maintenance / neglect flaws
if the car has been in an accident the engine & internals have likely seen stress that it wasn't designed for
Misaka_10032
Jan 27, 2019 01:36 PM
ROSS_BMW
Apr 9, 2015 05:44 AM
venmichaels
Apr 3, 2011 07:01 AM
d_stephen
Mar 30, 2008 09:32 AM
Z_Coaster
May 27, 2004 05:15 PM
