Hit A Bump, Car Didn't Stall On Spot, But Won't Start
Old Aug 28, 2019 | 11:39 AM
Zeplan_'s Avatar
Zeplan_
Default Hit A Bump, Car Didn't Stall On Spot, But Won't Start
New to the forum, in Aurora, Co
05 350z
Driving, hit a bump in the road near a construction zone, after that power steering got stiff. The car didn't stall or die out on spot, parked it shortly after (maybe not even a minute), once I parked the car did not want to start back up. Everything gets power, starter clicks, fuel pump engages, checked fuses and relays. Thinking maybe the crank sensor came loose? At work so no time to check it, any ideas as to what I should check?
Thanks in advance guys!
Old Aug 28, 2019 | 02:45 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
05 350z
First thing... Gonna sound silly but check your belt(s). P/S going flat, runs, subsequent no-start sounds like the P/S pump and alternator went South but retained just enough battery power to make everything WANT to do their thing but not enough to start.
Crank sensor is a good guess but that wouldn't explain the power steering going haywire. If the sensor is bad, you should be able to pull a code on it.
Old Aug 28, 2019 | 03:27 PM
Zeplan_'s Avatar
Zeplan_
Thought of that too but didn’t check lol thanks I appreciate it!
Old Aug 28, 2019 | 03:32 PM
MicVelo's Avatar
Good luck, hope it's as simple as that!
Micheal Wilds
Dec 27, 2019 03:59 AM
Bcmill4
Aug 18, 2016 07:34 AM
Reggierunion
Jan 25, 2015 03:56 PM
denic79
Mar 25, 2007 04:46 PM
Interlagos Fire
Oct 5, 2006 05:09 PM
