ac condenser question
Old Jan 31, 2020 | 09:55 AM
Jollyroger0612's Avatar
Jollyroger0612
Default ac condenser question
Is it possible to put the ac condenser infront of the radiator without removing the radiator? I would really like to avoid bleeding the coolant system, but I need to get the ac working. It's been an 80 degree winter in Florida this year with just a few cold days.
Old Jan 31, 2020 | 09:58 AM
813_350Z's Avatar
813_350Z
🤔 isn't it already in front of the radiator? Or do you mean between the radiator and the engine?
Old Jan 31, 2020 | 10:00 AM
Jollyroger0612
It was there, but I left it out when I was swapping out the blown motor. That was a mistake. I'm curious if I can get it back in without removing the radiator.
Old Jan 31, 2020 | 10:09 AM
813_350Z's Avatar
813_350Z
May be possible with a helper to do it. Remove the fans, have your helper push the radiator up out of the support and then back toward the engine (careful not to bend anything too much) and slide it in real quick. I can't say how easy it will be to get the connections back on though.
Old Jan 31, 2020 | 09:52 PM
rustyschopshop's Avatar
rustyschopshop
Highly doubt you can remove the fans without taking off the upper hose. Only way i can think to do it would be pulling the core support, would take some work and a couple helpers.
Old Feb 1, 2020 | 01:34 AM
813_350Z's Avatar
813_350Z
You're absolutely right, Rusty. I wasn't even thinking about that upper hose.
OP, please disregard my previous comment.
AGreenZ
Jun 7, 2015 06:28 PM
modd1uk
Sep 6, 2013 10:30 AM
chengie
Apr 3, 2013 04:42 PM
350sexZ
Jun 4, 2010 09:23 AM
