Grinding 3rd and 4th gears *05 350Z*
Hello, i have an issue with 3rd and 4th gear grind on my CD009 350z Trans
When i initially cold start my car, and take off, 3rd and 4th doesn't grind as much. And if i shift extra slow, it doesn't grind.
But once the engine warms up, it grinds like CRAZY. Like, I'm talking about KRRRRRRRRR. It sounds BAD. It grinds even HARDER when downshifting from 4th to 3rd, or from 5th to 4th.
Now, the gears DEFINITELY hold power. When i go into 3rd, it locks HARD, and doesn't pop out by itself.
All other gears are perfectly good, no grinds, goes in like butter. But what puzzles me is 3rd and 4th doesn't grind as bad when the car is cold. Could it be Oil? Slave cylinder? Or even worse.. Synchros?
Also, it has a brand new stage 4, 6 puck Clutch from ACT
Would love to hear any prior experience / insight on my issue.
Thanks!
P.S. I've attached a little video of the grinding. Eeek! it sounds GNARLY.
Thanks!
Since you're not certain of what product is in your tranny and it's past the 60K change point, you might try to change it out. I prefer Redline MT85 as it's a GL-4 rated lubricant with viscosity rated for what Nissan recommends. It was engineered with enough friction to allow the syncros to work properly.
Cozmos
Aug 16, 2017 01:59 PM
ssk0771
Sep 24, 2003 04:39 AM
