my 2nd gear feels weird again on my NEW TRANNY
Old Sep 1, 2003 | 09:27 PM
ssk0771's Avatar
ssk0771
Angry my 2nd gear feels weird again on my NEW TRANNY
I just got new transmission replace last thursday 8/28/03. I had problem with my 2nd gear. It felt like it was going to grind & felt a little knoch (something is blocking the way) when shifting from 1st to 2nd. Now that I have a new transmission, I thought every thing was going to be ok but now its starting to happen again. I am begining to feel the knoch again and my 5th & 6th gear is really stiff. Especially the 6th. sometimes I have to force it in
Is any one having same problem with their Tranny whether its your 1st tranny or 2nd (Espcially on 2nd gear)?
Old Sep 2, 2003 | 10:31 AM
christurismohk's Avatar
christurismohk
I've got my 2nd tranny, and yes....i have that weird 2nd gear again.....it seems as if i need much more effort to shift into 2nd compared to others.
Old Sep 3, 2003 | 11:55 AM
Shortbus's Avatar
Shortbus
I've had my Z for a little over 4 weeks now and have noticed the same thing in 2nd gear, about 80% of my shifts into that gear...
Christian -
Old Sep 3, 2003 | 12:26 PM
350ZNY's Avatar
350ZNY
Same problem here going into 2nd gear. The weird thing is it is like Shortbus said 80% of the time. The other 20% I get a perfect shift into second. How can it be as smooth as butter one time and lumpy the next time. It drives me nuts. Does this mean we are going to have tranny problems or is this normal?
Old Sep 3, 2003 | 12:39 PM
Stu E's Avatar
Stu E
Default Where did you have the replacement done?
SSK,
Where did you have your replacement done? I am just about to take mine into Performance Nissan in Duarte for the swap. At this point they say they have only seen one come back and it was an earlier transmission without the changes that have supposedly been made to the design.
Didi you have the celvis pin changes as well?
Thanks,
Stu E.
P.S. I just wonder if it's worth getting done if there's still a problem?
Old Sep 3, 2003 | 12:44 PM
WashUJon's Avatar
WashUJon
My tranny's been doing this since day one back in late January. It seems to shift better when the oil is warm, but there are plenty of "lumpy" shifts even then. There are just more buttery shifts as the gear oil gets warmer. Second is the only gear I have a problem with. The rest can sometimes feel a bit notchy, but nothing bad at all. Second actually clunks in hard sometimes unless I'm very careful and rev-match.
Old Sep 4, 2003 | 07:32 PM
ssk0771's Avatar
ssk0771
Default Re: Where did you have the replacement done?
Originally posted by Stu E
SSK,
Thanks,
Stu E.
I got mine done at Torrance Nissan. I dealt with a guy name Brett. He was very nice.
Also, from what I know, I think they did replace the pin.
As of now, It seems like 2nd gear is getting worse & worse. I am going to wait another week and take it back.
WHAT THE HELL IS WRONG WITH THE TRANNIES
Old Sep 5, 2003 | 07:24 AM
danzz's Avatar
danzz
Maybe they are built by a French subcontractor.
Old Sep 5, 2003 | 08:35 AM
WashUJon's Avatar
WashUJon
I bet the synchros are just not holding up for some reason. Maybe substandard parts/bad metal...
Old Sep 10, 2003 | 07:23 PM
ssk0771's Avatar
ssk0771
I went to Universal Nissan Today to get my tirepressure senor recalibrated. I talk to the Service Mananger Anthony and he was also having some issues with his 2nd gear. At first , He thought it was his imagination but after talking to some Z owner, He was not the only one. He said that I was his 5th customer that said the same thing. He gave me his business card and the took my phone number down. He said that he was going to order a new tranmission for this Z and do some investigation. He said he will get back to me.
Anthony was great.
Old Sep 11, 2003 | 02:26 AM
Shortbus's Avatar
Shortbus
Could be just me, but after hearing the un-repairing effects of replacing Z trannies, I'd now actually rather keep my originally factory installed tranny than have it replaced by anyone. At least i guess mine isn't ALL that bad. I call it a MOODY car, which what the Zs have been very reputable for. Unless of course this is actually causing damage to the tranny....
Christian -
Old Sep 23, 2003 | 10:39 PM
ssk0771's Avatar
ssk0771
Update.
last week I took my car to the dealer again because I was still having problem with my new tranny. I ask them to adjust my clutch to see if it will make it better. As of today, about a week after getting the clutch adjusted, I am still having problems with my 2nd gear.
Old Sep 24, 2003 | 04:05 AM
Shortbus's Avatar
Shortbus
Did I ever mention, if I double clutch my 2nd gear in my first couple of shifts after i start the car cold, it doesn't stick. On the other hand, it's starting to even grind sometimes on the first shifts if I don't double clutch it. Double Clutching is clutch, shift out of 1st into neutral, unclutch, reclutch then shift to 2nd.
In Europe you'd actually fail your driving exam if you don't double clutch through all your gears i hear from my sister :-o
Christian -
EDIT: The Boxster S I test drove also had a sticky 2nd gear and my boss said his 911 also has a sticky 2nd gear.
Who the heck knows....
Old Sep 24, 2003 | 04:39 AM
Blue Liquid's Avatar
Blue Liquid
My 04 has the exact same problems as mentioned by ssk0771 and shortbus. I'm also hesitant to have the factory installed tranny removed, so I'm going to wait and see if it gets worse.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Uriyo_
Sep 8, 2021 08:46 AM
sherm
Apr 11, 2020 05:21 PM
kyin
Oct 15, 2015 05:54 AM
